Reducing travel on ...
[Closed] Reducing travel on brand x ascend 170-150
Morning,
I’ve found a few posts talking about brass rods or zip tie mods. I couldn’t seem to see (unless I missed them) any additional channels for extra rods on mine. Is it possible to drop the travel down?
Thanks
Chris
[url= https://i.ibb.co/hK33rxB/32587-F71-96-A4-485-D-A67-D-05-A9646-FD066.jp g" target="_blank">https://i.ibb.co/hK33rxB/32587-F71-96-A4-485-D-A67-D-05-A9646-FD066.jp g"/> [/img][/url]
[url= https://i.ibb.co/c3LHvmK/B954-B719-8-C2-B-4-FF3-ADCD-055-FC27-F03-FD.jp g" target="_blank">https://i.ibb.co/c3LHvmK/B954-B719-8-C2-B-4-FF3-ADCD-055-FC27-F03-FD.jp g"/> [/img][/url]
Posted : 21/12/2021 9:48 am
No idea TBH, but why would you want to?
Posted : 21/12/2021 9:49 am
 jwh
see this post from last year.
https://singletrackworld.com/forum/topic/brand-x-ascend-xl-travel-reduce/
I've done it with small bits of zip tie for my son... which meant as he grew, i could just cut them down allowing him to use as much of the dropper as possible.
Posted : 21/12/2021 9:52 am
Depends which brand x. The older ones are the same as a Oneup V1 - you reduce them with a plastic spacer. The newer ones can’t be shortened from the research I did. The Oneup v2 you add in small brass spacers where the keys run - I’m not sure any brand x posts use this method.
Posted : 21/12/2021 10:58 am
Not 100% from your pic but that looks like the 'older' Brand X that you can use the plastic spacers (same as OneUp) method in. Did this for my GFs Brand X with cutting my own space from a take away carton. Zipties doe the same job as well I suspect.
Posted : 21/12/2021 11:40 am
Im guessing the post is too long making the swat too high. I can't use anything more than a 125mm dropper on my bikes which already have small frames.
Posted : 21/12/2021 12:53 pm
Thanks all. Yes it seems I had the older version so mocked up a shim from old mudguard from the dimensions here (post #370 if anyone is that interested!).
https://www.mtbr.com/threads/oneup-dropper-post.1075456/page-19
150 travel sorted
Brill!
[url= https://i.ibb.co/qrVjXNz/79-ADD93-C-7342-4426-B142-AE225-FBC6303.jp g" target="_blank">https://i.ibb.co/qrVjXNz/79-ADD93-C-7342-4426-B142-AE225-FBC6303.jp g"/> [/img][/url]
[url= https://i.ibb.co/m019ZrN/1-FA398-DA-9601-473-F-9-D3-D-E46-F12-CE3-DF1.jp g" target="_blank">https://i.ibb.co/m019ZrN/1-FA398-DA-9601-473-F-9-D3-D-E46-F12-CE3-DF1.jp g"/> [/img][/url]
[url= https://imgbb.com/ ]easy image hosting[/url]
Posted : 21/12/2021 1:06 pm
intheborders
New frame and got a 170 cheap. Thought it would work..but just too long…was worth having a tinker to shorten it.
Posted : 21/12/2021 1:10 pm
Swap it with someone? Easiest option
Posted : 21/12/2021 6:44 pm
