My fatty is optimised for 100 mm. Will the extra 20mm make much difference? Can I just run more sag?
If not do I need to get new bits or can you still adjust internally?
Posted : 19/06/2019 1:55 pm
Took my fatty from 100 to 120, just an airshaft change. Bit taller and slacker with no discernible downside.
Edit. Ah, reducing. Never!
Posted : 19/06/2019 1:59 pm
I shall leave them as they are then.
Posted : 19/06/2019 2:11 pm
If you want to do it, it’s just an air shaft change, I had a 100mm one to convert mine from 80mm, but plans changed and I went rigid. Don’t miss it.
Posted : 19/06/2019 2:17 pm
