Hopefully getting a Kaffenback frame this week - gonna mostly be using it for commuting but also quite fancy a bit of touring too. Not too familiar with racks - will any rack work ok? Any recommendations?
Thinking of getting the cheapo dhb panniers.
I am planning on swapping over most of the kit from my Planet X Superlight Alu - but I'm not sure if the wheels will take a wider touring tyre, or handle any 'light off-road' that the Kaffenback can apparently take (just thinking of canal towpaths anc cobbles etc really). Can't get the specs for the Superlight off the Planet X website any more for some reason. Any tyre recommendations? Something fairly fast for commuting but able to handle very light off road would be good.
Been looking at these mudguards - any good, owt better? http://www.wiggle.co.uk/p/Cycle/7/SKS_Chromoplastic_Mudguard_Set/5360010679/
Also been thinking about getting flat bars for it - seems like the only flat bars from wiggle etc are mtb ones, but I spose it doesn't matter. Bar ends?
Anyway, enough of my waffling - if anyone had any advice to offer it would be much appreciated.
tldr eh? 😥
Racks - tubus are amazing quality at an amazing price. Haven broken just about every other rack on the market over the years I got one and its great - very rigid mountings and very well made.
Cheers for that - looks good. http://www.cyclesportsuk.co.uk/product_info.php?products_id=4711 ?
Yes, I'll second the recommendation for a Tubus rack. I've got the Tubus Logo, which is good because the panniers sit a bit lower down so lower centre of gravity, and it makes it easier to attach things to the top of the rack as well. And as its made of steel it should last a bit longer than most other cheap alu racks.
I've also got those SKS mudguards, they are fine. I don't thinks there's anything much better than them.
For panniers, Ortlieb are great - very strong and completely waterproof, but not cheap.
Got some virtually new Altura Dryline panniers gonna be surplus to requirements shortly, 70 odd quid, can do em for 40 quid posted?
Could well be interested snakebite - what size are they? email is grum at sourpuss dot info btw. Cheers.
ortlieb panniers are very very good , Ive also heard that dhb at wiggle are not bad as a cheaper alternative. I got my ortliebs on e bay and imo they make a good s/h buy as they are so well made.
Like these, but all black. [url= http://www.bikedock.com/posit/shop/productinfo.php?partno=99314989&srcwind=%2Fposit%2Fshop%2Findex.php%3Fcategory%3D33%26group%3D8 ]null
They also have the side bits too attach rear lights too if you so wish. come with shoulder straps etc, as new and probably only used maybe a dozen short commutes to work.
I'll do some pics this evening if you want, can bung the Tortec rack in for another tenner? http://www.sjscycles.co.uk/product.asp?pf_id=13885&
OK thanks - was kind of thinking of the bigger ones but pics would be good, cheers.
tortec velocity rear rack like [url= http://www.zyro.co.uk/product_detail.asp?pid=2189 ]this[/url]
and tortec mud guards like [url= http://www.zyro.co.uk/product_detail.asp?pid=1469 ]this[/url]
looks like this:
[url= http://www.flickr.com/photos/mrmichaelwright/3250151583/ ]flivkr[/url]
the rack is very stable, i've done about 300 miles on it so far, some off road, some on road, both with one pannier and 100 miles with 2 panniers on a tour
i have altura dryline panniers, they seem to be good but are heavy as they are waterproof. my wife did LEJOG with her drylines last year and it rained nearly all the way but they kept it all out
only minor niggle is the mini v brakes catch the mudguards but a hacksaw is going to sort that out shortly
I really like my Tubus Vega nice an stylish in a minimal sort of way.
Tyres - 25mm Conti Gatorskins?
pics sent
Thanks folks.
How tall are you? I only ask, as it is an issue on my bike - albeit a small (cos I'm short) compact frame. the result is that the foward mounting points of the rack cannot be attached to the frame as they completely foul the brake. As a result, I'hve had to lash it up slightly using the seatpost. It's OK with lught stuff, but two full Ortlieb back rollers result in quite a waggle at the back end.
Just a smidgen under 5'8 - the bike is a medium kaffenback so on the verge of being too big for me.
What rack/frame is that with?
Delayed response:
Rack, er, a cheap Blackburn, I think (c.£20-25). Pretty flimsy compared with a Tubus.
Frame: Giant SCR, small size (I'm 5'7"). Giant frames are all very compact, and mine only measures 46.5cm c2c. the result is that there is no sensible way of attaching a rack to the frame eyelets at the top on the seat stays.
I reckon you'll be fine with a Kaff in medium - they're only semi-compact anyway. When buying a rack, it might be worth visiting your LBS, so you don't have to get stressed the night before you're going to Belgium for a week....
