Recommend me: a tor...
[Closed] Recommend me: a torque wrench
[#1253885]
Like it says above - one I can use to build/maintain my bike(s) so needs allen key fittings.
ta
Posted : 24/01/2010 2:14 pm
Norbar...excellent quality, quite dear...something like [url= http://www.norbar.com/Products/tabid/54/view/product/category_multid/1/range_multid/12/id/1180/Default.aspx ]this[/url]
All torque wrenches have either 3/8, 1/4or 1/2 drives, which then you fit an adapter on to use with sockets etc
Posted : 24/01/2010 2:18 pm
Norbar SL0
Posted : 24/01/2010 2:20 pm
Do you have carbon parts?
I never known one good all round torque wrench due to the small scale of 4Nm for bars and 65Nm for lock rings on cassettes and had to buy 2.
You want one for 0-15Nm and then one for the cranks and and cassette.
Could set you back £65 each and don't forget the calibration will need setting if you use it often which can be up to £30.
Draper, Sealey and even Halfords do some good stuff.
Also check Motorcycle shops/sites for similar Nm ranges.
They all have 3/8 or 1/2 inch drive fittings and hence will fit the allen key ends.
I chose 3/8 and use 1/2 inch adapter as I found it easier to find allen key ends in 3/8 sizes rather than 1/2" but it depends which shops are near you e.g. Halfords have all allen heads on 3/8" drives.
Posted : 24/01/2010 2:24 pm
Halfords Professional are very good. I have their 3/8" drive 10 to 110NM one and I'm very happy with it. I believe they do a 1/4" drive wrench that does something like 0 to 50NM and I'll be buying that one next.
Posted : 24/01/2010 2:36 pm
+1 for Halfords professional.
Posted : 24/01/2010 2:57 pm
+1 for the Norbar SL0
Not cheap but cheaper than replacing some carbon bars.
Posted : 24/01/2010 3:25 pm
[b]I believe they do a 1/4" drive wrench that does something like 0 to 50NM and I'll be buying that one next. [/b]
The smallest they do is, IIRC, a 6Nm to 50Nm, and is 3/8" drive. For the delicate stuff (carbon, low torque values) it's useless.
Posted : 24/01/2010 5:43 pm
