Recommend me a good...
[Closed] Recommend me a good ground anchor.....
[#6933931]
.....please. To bolt in, I'm not putting fresh concrete.
Thanks!
Posted : 15/03/2015 7:00 pm
Concrete in one of those flexible builders tubs, then fit a screw eyelet while the concrete is gong off ?
Posted : 15/03/2015 7:09 pm
Thanks but have a concrete for and don't want to dig out/ lay in fresh concrete
Posted : 15/03/2015 7:14 pm
I'm not talking about digging anything up. I mean create a block of solid concrete in a big bucket/tub and fit an anchor into that. Floor remains intact.
Posted : 15/03/2015 7:16 pm
Ah - ok thanks
Posted : 15/03/2015 7:18 pm
Hard to recommend mine, it's not been put to the test.
Abus, btw. Had a Kryptonite in the past.
Posted : 15/03/2015 7:32 pm
Hardie Large ground anchor?
http://www.locktrader.co.uk/Hardie-Ground-Anchor-Large.html
When we moved my BIL had a right Biatch of a job to remove it and it's not damaged, unlike the floor 🙂 🙂
Posted : 15/03/2015 8:19 pm
Abus wba100 for about £50 and a 16/19 mm chain with squire ss65cs padlock.
Posted : 15/03/2015 8:47 pm
Cheers chaps!
Posted : 15/03/2015 8:52 pm
Pragmasys (sis?)
Posted : 15/03/2015 9:39 pm
Abus here, dunno what model. I tried to saw it & file it but no go so it would be an angle grinder job. Plus there's 3 bikes in the way before you can get to it. The chain is one that Ripon Engineering said was the best they had & the lock is a big fat Kasp. Easy enough to pinch with a grinder through the chain I suppose, as most would be. If they want it, they'll take it.
[url= https://farm5.staticflickr.com/4127/4993562416_bd2043db0e.jp g" target="_blank">https://farm5.staticflickr.com/4127/4993562416_bd2043db0e.jp g"/> [/img][/url][url= https://flic.kr/p/8Bgj8J ]Ground Anchor & lock.[/url] by [url= https://www.flickr.com/people/7904024@N08/ ]jimmyg352[/url], on Flickr
Posted : 15/03/2015 10:16 pm
Another +1 for the Pragmasis. I have one in my garage along with their 13mm chain. Relatively easy to fit using resin bonded bolts.
http://securityforbikes.com/torc-ground-anchor.php
Posted : 15/03/2015 10:37 pm
 womp
I use this anchor chemical bonded with an Almax 16mm chain
Posted : 15/03/2015 10:46 pm
I use these, seam fine and £15:
http://www.screwfix.com/p/master-lock-wall-floor-anchor-steel-large-160mm/49778
Posted : 17/03/2015 8:58 am
womp where the heck did you find that? in a bathroom chain store or a designer outlet...whats with the chrome finish? there's some good suggestions here.
Posted : 17/03/2015 9:36 am
Thanks again chaps. Good reminder about pragmasis - I had a monster chain off them a few years back.
Posted : 17/03/2015 10:01 pm
[quote=muddy9mtb said]womp where the heck did you find that? in a bathroom chain store or a designer outlet...whats with the chrome finish? there's some good suggestions here.
http://longstart.co.uk/
Posted : 17/03/2015 10:04 pm
