Recommend me a 32t ...
[Closed] Recommend me a 32t chainring for a 1 x 9 set up
[#1548571]
thinking of giving a 1 x 9 a try - will run a SLX crank with a bash and a jump stop.
any recomendations for a suitable (unramped) chainring?
Posted : 26/04/2010 10:49 pm
Don't do it you will die.
Posted : 26/04/2010 10:52 pm
[url= http://www.coventrycyclecentre.co.uk/products.php?plid=m11b0s113p1677 ]These E 13 rings look pretty cool![/url]
Posted : 26/04/2010 11:01 pm
how about a Gamut? I have one on my ss. Selling mine with 50ish miles use if you are interested as I am getting a 33t one so I can dispense with the tensioner.
Posted : 26/04/2010 11:05 pm
Hoping my E13 G ring wears out soon so I can buy one of [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=40426 ]THESE[/url]
Posted : 26/04/2010 11:06 pm
BETD have their Goldtec ones for 15 quid at the mo.
Posted : 26/04/2010 11:08 pm
salsa
Shimano Deore.
Posted : 26/04/2010 11:10 pm
E 13 for me at the moment.
Posted : 26/04/2010 11:12 pm
 Del
surly.
mines done about 4 years now, used at least once/week, if not three times. i did flip it over this winter though. 🙂
Posted : 27/04/2010 9:41 am
Surly for sure. Steel and tall teeth so the chain won't fall off. Unfortunately no lateral strengthening so it can fold over if you run it 2x9 and get a nasty shift.
Posted : 27/04/2010 9:54 am
I got a Blackspire Mono Veloce Single Speed 7075 Series
http://www.chainreactioncycles.com/Models.aspx?ModelID=28730
though 32t out of stock at mo at CRC
Posted : 27/04/2010 10:05 am
I used to think surly was good until this happened the other week:
What an overpriced piece of junk. Deore costs 75% less and doesn't fold over if a chainring bolt falls out.
Posted : 27/04/2010 10:07 am
perhaps you should check you chainring bolts more frequently - they are there for a reason 😉
Posted : 27/04/2010 10:12 am
thanks rootes1 🙄
I check most rides but I find SS bolts are particularly crap. The Surly ring is still poostain
Posted : 27/04/2010 10:16 am
hey leggyblonde, try a blob of retaining fluid under the tops of the chainring bolts ([b]not[/b] threadlock on threads). I had a surly ring thought it was fine, but then have not lost a bolt.
ta Si
Posted : 27/04/2010 10:22 am
 Del
hmm. loctite? or steel bolts? or both?
any chainring will fold if it's not fixed properly.
Did your frame survive that leggyblond? I drove the granny into the chainstay one time and wrote it off 🙁
Posted : 27/04/2010 10:25 am
Hoping my E13 G ring wears out soon so I can buy one of THESE
£40 for a single chainring? bloody hell...
Posted : 27/04/2010 10:29 am
Sorry Dell, that's rubbish. I lent a bloke at SSEC a bolt (which is why I only had 3!) as two of his had fallen out. His was creaking but hadn't folded. I've seen loads of people ride with a bolt missing without any problems but it appears surly rings are known for folding.
rootes1, why retaining fluid and not loctite?
and yeah the frame survived thanks, finest taiwanese wrought iron 😉
Posted : 27/04/2010 10:32 am
Retaining fluid is a type 'loctite' other providers of industrial adhesives are available..)
loctite make lots of different types of eng adhesives some are threadlockers, some are retainers etc.
Some time and for things you might to take apart using a threadlock is overkill and all you need is to put a decent retaining fluid under the head of a bolt/on the shank - this is enough to stop the bolt coming undone in use, but makes it easier to take off. I use Loctite 638 and 648 on engine conrod bolts for example - holds them firm, but you have still take apart when needed also not put threadlock on means you get truer torque readings
For bikes Loctite Stud and bearing fit (#270) and Retainer 603 are ideal for seating beaings in housings, round the edge of chainring bolts etc
Posted : 27/04/2010 10:40 am
Try [url= http://www.velosolo.co.uk/shopcrank.html ]these[/url], they charge a bit on carriage, but it was the only place I found that had some in stock and it's round with teeth on!
Posted : 27/04/2010 10:44 am
