Reba RL 2012.. Can ...
[Closed] Reba RL 2012.. Can the fork be increased from 100mm to 120mm travel?
Ive googled and worked my way through forums but there dosent seem to be a definitive answer for the Reba RL.
Could any one shed some light on this please? Is it easy?
Posted : 13/08/2012 4:35 pm
 LoCo
Yes it is easy if there's a spacer inside the air spring system, however not all can be increased, it depends on whether they're O.E or aftermarket and how they were specced when they were built, easiest way to check is strip the air spring system out and see.
Refer to the SRAM site for instructions.
http://www.sram.com/service/rockshox/7,103,434
Posted : 13/08/2012 4:38 pm
How much would a set cost me if I bought them from you?
29er, 120mm, 15 or 20mm and tapered in black.
Thanks for all the info.
Posted : 13/08/2012 4:57 pm
 LoCo
Hi Ska, drop me a mail (in profile) and I can give you a quote ๐Ÿ˜€
Posted : 13/08/2012 5:08 pm
