Rear wheel for 135m...
[Closed] Rear wheel for 135mm Maxle?
I have very little experience of rear wheels and hubs. I need to buy one for new build and don't know where to start. I don't want to spend the earth but want a decentish wheel I can buy new online and fit before the wknd...
Any ideas or suggestions would be gratefully received.
Posted : 29/05/2012 12:04 am
What is rear maxle? Is that 12mm bolt through? If so Pro2 is obvious choice.
If you need one, I have a Pro2 12x135 rear axle, and a DT Swiss 240S 12x135 axle both to sell.
Posted : 29/05/2012 12:37 am
Pro 2's a bad choice- Pro 2 Evo would be good though. Old Pro 2 likes to snap axles when used with a maxle (does so very quickly with a tapered old design maxle lite or similiar, I've done 2 with full thickness axles though)
Posted : 29/05/2012 12:47 am
Yes it's the 12mm job, but I already have the axles thanks. Its a full rear wheel build I need now.
Thanks for advice - How much do you reckon a pro 2 evo wheelbuild with a decent rim will be?
Posted : 29/05/2012 12:13 pm
