Rear tyre for the w...
[Closed] Rear tyre for the wet season?
 hock
[#5520431]
Based on advice here I have found an excellent mud tyre for the front (Bontrager Mud X). Very controlled and even if it let's go eventually it is still a controlled slide.
What would you recommend as a tyre for the rear, that bites/grinds with good traction up-hill through slimy, muddy stuff and the odd wet root/rock [i]but still rolls okay[/i]?
Maxxis Ignitor any good?
I have currently 2.35 Minions on the front and will switch back to the 2.0 Mud Xs if things get too sloggy later in the year. I currently have a 2.4 Maxxis Ardent on the rear which was okay in the dry but those shallow, ramped mid-blocks are useless as soon as it get's wet-ish.
Was always amazed by Nobby Nick up-hill traction in the goo but don't like their lack of control in corners. Purgatorys were okay but not great.
Thanks!
hock
P.S.: We are talking 26 hardtail trail biking in clay/sand/dirt woddy area, not rocky.
Posted : 16/09/2013 11:42 am
another bonty Mud-X? They're really not that draggy.
Posted : 16/09/2013 11:43 am
Have you actually tried a Mux-X on the back? I run a pair when the conditions turn to slop and am actually looking forward to putting them on because they're so fast on the road too, well compared to a UST rubber queen.
Posted : 16/09/2013 11:55 am
Maxxis Medusa or Conti Mud king. The conti cuts through the deepest of mud.
Posted : 16/09/2013 12:11 pm
 hock
another bonty Mud-X
Hm, havn't thought about them as a [i]rear [/i]tyre based on "how they look" but certainly worth a test while the Minion ist still okay for the front.
If it works I could try to get the wider and/or softer compound ones for the front.
Cheers! 🙂
Posted : 16/09/2013 12:12 pm
I was running Bontrager XR4's front & rear in yesterdays Mary Towneley Loop Challenge & I really couldn't fault them.
The conditions were truly horrendous and I don't think you could get much wetter, muddier conditions than that!
Posted : 16/09/2013 12:14 pm
I think the XR-Mud / Mud-X is a better rear tyre than front tyre.
Posted : 16/09/2013 12:15 pm
I agree.
My XC hardtail has a Mud-x on the back and a 42a Minion on the front. Same combo all through last Winter and this Summer too.
Posted : 16/09/2013 12:28 pm
It does'nt aiways work but some tyres that are not good in the wetter weather, work pretty good run in the wrong direction of rotation. Its a good way to run off your old part worn tyres.
Posted : 16/09/2013 12:35 pm
You're wasting your time. It's still summer for at least another month or two. Isn't it?
Posted : 16/09/2013 12:36 pm
Well looking at the long range forecast summer is back as of friday down south, I'll keep my small block 8s on.
Storm Control's are equally as good as Mud X, if not better rolling IMO.
Posted : 16/09/2013 12:39 pm
 hock
I like your thinking! Not sure if that works on the rear, though? 😉
Posted : 16/09/2013 12:50 pm
the best set up i have found for muddy south wales trails is a wet scream 2.2 on the front and a high roller on the rear.
2.4 ardents are just like having a surf board attached your bike. no other front tyre comes close to the wet scream, not to bothered about the rear but i do like a fast rolling tyre in the summer like an ardent or crossmark and a high roller/minion in the winter.
has anyone tried the rubber queens for an all round tyre?
Posted : 16/09/2013 1:15 pm
Yes, in my experience rubber queens have nowhere near big enough knobblies to dig in unless you want to run very low pressures, they also clog like mad and soon become like slicks.
Posted : 16/09/2013 1:21 pm
ok cheers fella
so looks like i will be sticking to the wet scream this winter again.
are the good rolling or draggy
Posted : 16/09/2013 1:24 pm
 hock
[u]Just a little update:[/u]
- tried 2.0 Bonty MudX on the rear and... hated it! Too shallow! Got too used to wider/taller stuff...
- fitted leftover 2.4 Nobby Nic on the rear and - as always - Nobby Nics are certainly not great in the mud BUT they keep you going. Somehow and with a lot of slip I made most muddy inclines despite the rear being clogged up. Amazing! But 2.4 with mud rubs Soul chainstays -> not sustainable!
- I'll switch to a High Roller as soon as I can get hold of one.
On the front? My brave Minions were send into hibernation as I've found a dusty Specialized Enduro 2.4 tyre full of cob-webs (literally) in the very back of my LBS' tyre rag. After being dusted off the LBS gave me a very fair price and still giggled. They have a very nice open tread and super soft rubber on the shoulders. So far I like them.
Cheers!
Posted : 15/11/2013 8:40 pm
 hock
Another update:
- switched front-to-rear, as Highrollers on the rear were almost as useless as Ardents: sudden slip, just a little later, those ramped middle blocks are sh#te for traction when slippery to muddy
- but above mentioned Spesh Enduro truly excellent on the rear!
- same tyre was side-knob flapping into oversteer all the time when on the front
- Highrollers upfront now, perform OKish but not as good as Bonty MudX (less control, more glide)
-> 2.0 Bonty MudX on the front, Spesh Enduro 2.4 on the rear? Will probably look like a dragster but might work.
2.2 Conti Rubber Queen reduced at the bike shop. Might be the solution for more tyre-space for those gluey-muddy-rides around 0°C...
Posted : 10/12/2013 10:34 pm
I'd vote for a trailraker, and they're not that slow if you pump them up hard. You need to run quite high pressures as they are skinny. They are a real 'cutter' of a mud tyre, very good for drive. Not so good on roots and rocks, but you said you didn't need that.
Posted : 10/12/2013 10:39 pm
Have you tried the HR's the other way round? Braking traction might not be up to par, but it's muddy anyway, and having the ramp on the trailing edge instead of the leading one might afford a little more grip?
Posted : 10/12/2013 10:47 pm
 hock
yeah, thought about that, too - not tried yet, though
Posted : 10/12/2013 11:42 pm
 adsh
Maxxi Beaver are very good. Good traction and quite fast.
Posted : 11/12/2013 9:35 am
