rear shock leaking ...
[Closed] rear shock leaking air from valve after pumping up
Is there hope when this happens to save a shock? Anyone know if this is a warning sign of the shock being broken or if it's common and all I need is a new valve stem. I haven't got a core remover but would a bike shop be able to help?
Posted : 07/08/2015 8:18 pm
Probably just needs tightening (the valve core that is).
Posted : 07/08/2015 10:16 pm
What Benpinnick says. Whip out the valve core, make sure its clean and then pop it back in.
Posted : 07/08/2015 10:45 pm
Can you actually hear the air leaking out of the valve?
Or are you by any chance pumping the shock up to a certain pressure then removing the shock pump and then screwing the pump back on and reading a lower pressure?
Because then the air escapes from the shock back into the pump and the pressure gauge shows a lower reading.
I only mention this because people used to do this all the time when I worked in a shop.
Posted : 07/08/2015 10:52 pm
Can hear it hissing away out of the pin/valve in one go after a 2mins it's stopped and hardly any air left. If I pump it up and put the cap on it actually stops but imagine it would only be a matter of time maybe an hour before it would slowly leak out as I think those caps are only really dust caps and not sealed but it sure does stop the hiss sound.
Think I'll go to Halfords and buy a £4 core remover tightener tool (or can I just tighten it with my fingers?) rather than bother a bike shop again. Sounds like you just turn anti-clockwise to un-do and clockwise to tighten?
Posted : 07/08/2015 10:59 pm
If you can wait, try eBay, I got a core tool and 20 new cores for a couple of quid!
Posted : 07/08/2015 11:10 pm
Thanks everyone. I got the stans no tubes valve core remover tool and replaced the core with a conti' inner tube one and it seems to have stopped the leak. Very good news, wish all shock issues were as easy as this.
Posted : 08/08/2015 9:41 pm
