Rear shock for a 20...
[Closed] Rear shock for a 2005 Turner 5-spot?
I'm trying to do a bit of bike upgrading but it's proving harder than it should be to give away money!
I'm looking at replacing the old Romic coil with an air shock; I was after a Rockshox Monarch RC3 but it seems they simply don't exist, nowhere has any stock at all and can't get hold of any more. Which is a bit of a bugger because I had sort of got my heart set on it after lots of research.
So what else is worth a punt that you can actually get hold of? I wanted something different from a Fox (the last Fox shock I had was utterly unreliable, and they're more expensive too) but I'd quite like the improved compression damping of the RC3 over the RT3 monarch (this is of course assuming that anyone actually has an RT3...)
Is there anything else worth looking at?
It seems to be a growing phenomenon that while the choice of components is quite large the range that you can [i]actually get hold of[/i] is an awful lot shorter...
Phil
Posted : 07/11/2011 11:14 pm
I know it might not be what you are after but I have both a Van RC coil and a Float RP2/3 to sell if you are interested.
Posted : 07/11/2011 11:26 pm
Rosebikes had cheap Monarchs in a short length recently
Posted : 07/11/2011 11:27 pm
They did, but while I was deliberating as to why they were so cheap they sold out... ๐Ÿ™
Vortexracing, thanks but not quite what I'm looking for (assuming anything else actually exists!)
Posted : 07/11/2011 11:34 pm
No probs, not wanting to rub it in , but the fox shocks are for sale because I managed to get my hands on a RC3 ๐Ÿ™„
Sorry
Posted : 07/11/2011 11:38 pm
You probably got the last one! ๐Ÿ™‚
Posted : 08/11/2011 12:32 am
if you want to import one drop me an email.
Posted : 08/11/2011 12:37 am
I just got a rp2 2nd hand for mine, works well
Posted : 08/11/2011 2:17 am
When I had a Horst link 5 Spot a 'PUSH' tuned RP3 was regarded the best rear shock.
Buy a cheap used one & send it to TFT for tune & refurb.
Posted : 08/11/2011 7:39 am
I've got a DHX5 air I took off my 5 Spot. You'd want to get it serviced/upgraded, but it's yours for not a lot if you want it.
Posted : 08/11/2011 8:45 am
Not sure this is much use to you but I recently changed out a Monarch R on a Salsa Spearfish to an RT3. Difference is noticeable when in platform mode and wide open, just seems a much smoother shock and also definite difference in all 3 positions. On my Five I have a pushed RP3 and find very little difference in the settings compared to the RS although the Push did help it stop blowing through its travel.
But, all very difference suspension systems to yours. the RT3 does get lots of love of the MTBR forums when I looked last.
Posted : 08/11/2011 9:26 am
RP3 on mine - works a treat, never had any problems in the three or four years it's been on. I've swapped out the seals, and gave it a service about 2 years ago and make sure it gets cleaned and lubed after each ride.
Posted : 08/11/2011 10:24 am
 LoCo
Fox or CCDB
Posted : 08/11/2011 10:27 am
Still using the original Romic on my 04 Spot, far better than any air shock I've tried on it, but it's a bit of a pig to service compared with the DHX coil on my sixpack
Posted : 08/11/2011 11:30 am
Coil. 5 Spots should always have a coil!
Posted : 08/11/2011 11:39 am
Have you tried bike-components.de? Earlier in the year a bunch of people were getting Sectors at cheap prices from them. I don't know if there pricing is competative on the RC3 but they seem to have a big selection marked as in stock.
Looks like they have RC3 shock in 2011 2012 models and regular and high volume housings.
Posted : 08/11/2011 11:49 am
The Romic it has at the moment seems fine, despite having not been serviced or had its bushings replaced in years, but I'd just like something lighter for everyday use.
Rusty, thanks, I hadn't noticed them - will give them a try. I would put money on having the same "we didn't know the distributors haven't got any" though; they're still showing in stock at the three places I've ordered one from already!
Why is it so difficult to give away money...
Posted : 08/11/2011 2:02 pm
 JonR
I've got a Pushed fox RP23 I'll be looking to sell in the next couple of weeks. It's losing a bit of oil on rides so it will need a service and I wouldn't be wanting too much for it.
Posted : 08/11/2011 2:56 pm
Mine is nice on an RP23, older model pre boost valve stylee.
Posted : 08/11/2011 3:03 pm
