Rear pivot - Giant ...
[Closed] Rear pivot - Giant Anthem
[#3748280]
I've just bought a replacement set of rear pivot bolts from my 08 Anthem as the original collapsed. The original has the threaded nut, a 'washer' and the bearing race, with the washer seemingly 'stuck' on. The new set has a separate threaded nut, washer and bearing race. Do I need to glue the washer to the bearing race, or just fit it all and hope years of muck will keep it there?
Cheers!
TS
Posted : 07/03/2012 9:44 am
When you tighten the bolt will it not simply pull everything into place and hold it there?
Hard to understand what the problem is and chance of some photo's?
Posted : 07/03/2012 10:15 am
never glue a bearing
Posted : 07/03/2012 10:35 am
Don't know if its the same setup, but when I stripped the rear end of my 2011 anthem down, nothing was stuck together.
Posted : 07/03/2012 11:53 am
Cheers folks. I'm pretty sure the washer/spacer doesn't need fixed in anyway and that tightening it all up together will do the trick, I just wanted some reassurance that I wasn't missing something obvious!
TS
Posted : 07/03/2012 3:34 pm
If you can't pull it off then it should be OK!
Posted : 07/03/2012 9:46 pm
