rear hub question: ...
[Closed] rear hub question: think i can't do this but will ask anyway
2 Users
I've inherited a set of wheels with an XT M756 rear hub. Can it be converted to 10mm rear axle?
I'm pretty sure it can't, I just wanted to see if someone with more knowledge than me knew if it could be done
Posted : 08/04/2014 9:25 am
If you mean 10 mm through-axle then no. You could replace the qr axle with a nutted one ( like on a cheap or old bike) easily enough which is a faff and requires a 15 mm spanner to take the wheel off, but a bit stiffer than qr. i woudnt bother though, you can get a superstar hub and have them supply it with 10 mm adapters for no extra cost.
Posted : 08/04/2014 9:31 am
thought so, just checking
thank you
Posted : 08/04/2014 9:34 am
