Rear cone adjustmen...
[Closed] Rear cone adjustment
[#878958]
Hi all
How do you adjust out movement from a rear hub? I've taken the rear QR out and removed the retaining 16mm nut. I've then remove the large washer, I still can't see the cone to adjust it. Help!
Posted : 18/09/2009 6:18 pm
Are you sure it has cones? That description sounds like it might be sealed bearings, which need pulling out and replacing as a unit.
Posted : 18/09/2009 6:20 pm
it's probably under the conical rubbery washer
Posted : 18/09/2009 6:21 pm
