Rear brake vibratio...
[Closed] Rear brake vibration
4 Users
My rear disc brake has just started to vibrate when squeezed/used...
Checked it over, but I cant see what the problem, any ideas please ?
Posted : 07/04/2009 9:55 am
Loose caliper, loose disk, warped disk...
Posted : 07/04/2009 9:58 am
Tighten all bolts on calpier, disc etc...
Then try retarding the pistons slightly, remove pads, clean with isoprpyl alchohol/disc brake cleaner etc. with cotton bud, re-lube pistons with brake fluid (careful not to get on paint if using Dot fluid), put pads back in and re-set pads...
Worked for me and TheGingerOne
Posted : 07/04/2009 10:11 am
Loose/worn hub bearings can also cause it.
Posted : 07/04/2009 10:22 am
