Since I've no longer had use of a van, I've had to take my bike apart to fit it in the car.
Doing this a few times has caused my rotors to rub on the pads. So today I thought I would try and adjust them but have just made things worse.
I'm going to take the bike into my LBS tomorrow, how much would I expect to pay to re-seat the front brake pads and bleed the front and back brakes?
Posted : 05/09/2010 7:52 pm
if you're using Avid brakes gently put a large flat bladed screwdriver between the pads and use it to push them apart. Then put the wheel back in and pump the brake a few times, that will reset all. The next time you transport the bike put the pad spacers in that will stop any accidental knocks on the levers causing this problem.
Posted : 05/09/2010 8:19 pm
Thanks for the tip joolsburger.
Posted : 05/09/2010 8:35 pm
