RaceFace Turbine Cr...
[Closed] RaceFace Turbine Crank Chainring BCD Please?
I thought these were "standard" 104BCD. I'd take the cranks off to check, but there's a chainguide in the way. I want to replace these for a 30 or a 32T, but I'm not sure how to work out the BCD.
Hopped on the RaceFace website, but they have multiple BCDs (for doubles and I think 5 bolt BCDs?) which is confusing me.
http://www.raceface.com/components/cranks/turbine/turbine-crank/
I definitely have the normal Turbines, not the fancy direct mount Cinch version.
Anyone care to help me out please?
Posted : 07/05/2015 12:14 pm
Some were 104 bcd, some were 120...
Posted : 07/05/2015 12:38 pm
On that site, the vivid green cranks are 104bcd, all the rest are 120bcd.
Posted : 07/05/2015 12:42 pm
I'm pretty sure 3x10 are 104, 2x10 are 120. My 4arm 3x10 are 104.
Posted : 07/05/2015 12:46 pm
They made a 2x10 doubles using the 104bcd as well. The chainline was slightly different according to the website
Posted : 07/05/2015 12:49 pm
I have a 5 arm 110bcd square taper Turbine.
Posted : 07/05/2015 12:50 pm
Thanks for the responses so far!
The cranks came on a new bike. It looks like it will take a double, but is set up as a single ring. I'm trying to avoid having to remove the chain guide to have a look because I want to avoid tinkering with it if I don't have to.
Posted : 07/05/2015 12:54 pm
[url= http://www.wolftoothcomponents.com/pages/how-to-measure-bolt-circle-diameter-bcd ]here[/url]
Measure the bcd yourself? it's not hard.
Posted : 07/05/2015 12:57 pm
How would a chainguide stop you measuring BCD?
Just run a ruler (or better a vernier) across 2 of the bolts diagonally measuring bolt centre to bolt centre.
Triples are 64/104, doubles are either 64/104 or 80/120 depending on size of rings. It's not super easy with a ruler given the crank is in the way but you're only trying to work out if it's 104 or 120, not measure it exactly - and that will be obvious.
Posted : 07/05/2015 1:02 pm
Tried to measure the BCD, but I can't get a 100% accurate measurement because of the curve of the spider. Wish I had some Vernier callipers. Perhaps this is an excuse to get some!
I tried the adjacent bolt measurement as well, but I can't get an accurate enough measurement with a tape measure. I'll dig the ruler out this afternoon and have a go.
Posted : 07/05/2015 1:08 pm
Assuming they're 4 bolt, if you can get to two opposite bolts, then just measure across the bolt holes, centre to centre. They'll be either industry standard 104mm or SRAM 2x specific "standard" 120mm.
Posted : 07/05/2015 1:11 pm
Good news and better news! It's 104mm BCD and a 32T.
Means I have the option of taking the 30T with me as a backup, but I don't need to buy a weird BCD chainring.
Posted : 07/05/2015 6:08 pm
Told you that 4 hours ago
Posted : 07/05/2015 6:27 pm
