RaceFace Deus XC Si...
[Closed] RaceFace Deus XC Singlespeed 08/09 Crank Bolt!!
[#2351452]
OK, I've given in and am resorting to the forum.
I managed to strip the thread on the crank bolt and need a replacement. RaceFace have kindly made their website 2011 only with no archived manuals or other details. I cannot find the bolt I want anywhere having already sent back one which was labelled Deus XC.
Basically its 15mm with 1mm thread pitch and 8mm hex to fit.
Anyone send me a link?
Maybe I'm mechanically inept but all these cranks want to do for me is fall off.
Posted : 09/01/2011 8:06 pm
For info this is a two part system, a puller cap with 10mm allen hex and the seperate internal bolt which holds the drive side crank arm to the spindle. It's the internal bolt with the washer that I'm after.
Posted : 09/01/2011 8:28 pm
My set of Evolve cranks of a simlar vintage are lying in the spares bin after the splines died. Think I've still got the bolt & puller cap too. If I can find the bolt and it matches those dimensions then I'll post it to you, its of no use to me, I just hate throwning things out, even when they're buggered!
Rob
Posted : 09/01/2011 8:51 pm
Mmmm, just had the vernier on it. Thread pitch is 1mm, but the outside diameter on the thread is 17,8mm.
Posted : 09/01/2011 9:31 pm
Cheers anyway, I've got Silverfish on the case too...
Posted : 11/01/2011 8:48 pm
Hi YorkshireRipper
This is no biggy for us, we should have a load of them so I'm not sure who you have spoken to / mailed at the office but give me a yell if you dont get much joy from them: richie@silverfish-uk.com
Please be aware, I'll be out of the office tomorrow but back in on Friday.
Posted : 12/01/2011 11:59 pm
Sorted, cheers Silverfish.
"The correct part number is F30018, which is a kit to replace both the crank bolt and extracting cap (due to a design change you are best off replacing both)"
Posted : 15/01/2011 6:07 pm
