Quick Question - wh...
[Closed] Quick Question - where to buy HTII crank arm pinch bolts
I can't see them on CRC (though I don't really know what I should be searching for)
Posted : 04/08/2010 3:01 pm
some disc caliper mount bolts fit.
Posted : 04/08/2010 3:02 pm
i filed down a disk caliper bolt.
Posted : 04/08/2010 3:03 pm
It's just a standard hex head bolt. Nothing special at all. I think I might have some spares in my toolbox, drop me an email (In profile) if you get stuck and I'll post you a couple.
Posted : 04/08/2010 3:05 pm
Oh right! Cheers Peter, I will do should I get stuck.
Thanks all!
Posted : 04/08/2010 3:06 pm
Yup M6 and the orignals are prone to rounding, use a caliper bolt or similar.
As above, standard M6 cap head bolts fit - just. If you're replacing, get longer ones which will reduce the risk of stripping the crank threads (been there, done that, got the T-shirt....)
Posted : 04/08/2010 3:08 pm
 Pook
have you found the cap?
Posted : 04/08/2010 3:09 pm
I got some from somwhere - let me think
Edit: http://www.singletrackworld.com/forum/topic/xt-crank-clamp-bolt-m6-x-19-amp-washer
Posted : 04/08/2010 3:11 pm
