Quick Q - Fox Air C...
[Closed] Quick Q - Fox Air Can Service
[#1012171]
Instead of 2.5ml of Float Fluid or whatever it's called, can I use fork oil?
TIA
Posted : 04/11/2009 2:47 pm
I have in the past
Fox stuff is just 85w gearbox oil BTW
Posted : 04/11/2009 2:49 pm
So a heavier wt oil would be better then? I have some 20wt I think, might give that a go!
Posted : 04/11/2009 3:14 pm
 RicB
As uplink says, just get some gearbox oil from a motorbike shop.
I've used 15wt with no problems. I tend to squirt 2ml into the shock using a shock pump every few months- means I don't need to take the can off 🙂
Posted : 04/11/2009 5:11 pm
