quick gps question ...
[Closed] quick gps question (joining waypoints)
2 Users
Trying desperately to get this [url= http://tinyurl.com/c2gkd4m ]route[/url]
into a joined gps file. I've downloaded babel and then uploaded to ridewithgps and it has split it up into 6 routes. How do i join all these routes into a single route?
Posted : 03/09/2012 4:16 pm
I don't understand how you've got it split into six parts? I just managed to download the KML file (one route) and convert it in GPSies to a CRS or GPX (both still one file). 😕
Edit: Realised what you've done! You must have saved each individual section.
Click on KML instead.
Posted : 03/09/2012 5:25 pm
hi,
I didn't create the map. I found it 🙂
Downloaded the kml and it still loads as 6 seperate routes. I've even uploaded the kml and converted gpx to ridewithgps and it still splits into 6 seperate routes 🙁
Posted : 04/09/2012 8:54 am
I know you didn't create the route. I thought you'd clicked on the separate sections and were trying to join them up.
Try using the GPSies site instead...It loads as one route for me in the track creator. If it does load as six for you, you should be able to save it as one from there, in whatever format you want.
If for some reason it's still split into six on your GPS, could you not just display all six on the map, rather than trying to load them as routes?
Edit: To save all this hassle, you could download the GPX from [url= http://www.gps-routes.co.uk/routes/home.nsf/RoutesLinksWalks/the-ridgeway-walking-route ]here[/url].
Posted : 04/09/2012 11:03 am
