if i strip a set of rlc forks and a set of r forks both air/140mm and 32mm can i swap the rlc workings into the r and will it work
ie a set of float r change to rlc and swap my talas rlc to r ?
i cant see why not but thought id check
oh and while we are at it i know i can swap talas to float but can you convert them to vanilla or are the stantions (sp) different at all in the air / coil forks
thanks
Posted : 08/03/2010 6:48 pm
see no reason why not, other than the adjustment dials on top not 'fitting' as such.
mojo are your friends....perhaps....
Posted : 08/03/2010 7:04 pm
aye i'll give them a bell tomorrow
Posted : 08/03/2010 7:10 pm
You can go to vanilla, but cant go back to float/talas because the spring will mark the internal surfaces required for air seals
Posted : 08/03/2010 8:51 pm
