[Closed] Quick BB7 post mount question
Just got some Toras to fit to my dad's bike. They are post mount. Do I need an adaptor to fit his BB7? Had a look on crc at all the post/is avid mounts and got thoroughly confused ๐ณ
Posted : 27/10/2009 12:44 pm
Posted : 27/10/2009 12:48 pm
mrs j has a bb7 on a post mount manitou fork with 160mm rotor. No mounts, just the cup'n'cone washers straight into the post mount on the fork. (you need the washers otherwise the calliper will be too close to the axle). HTH
Posted : 27/10/2009 12:55 pm
Cheers guys - it's a 160mm rotor, so should be fine then.
Posted : 27/10/2009 12:57 pm
No mount needed unless your going bigger than a 160mm rotor, just remove it from the IS adapter and fit it straight on.
