Quick access to cam...
[Closed] Quick access to camera on bike pack?
[#7094444]
I'd like something to enable quick access to the camera whilst on the bike - just a point and shoot, soon to be replaced with a rugged model of some sort.
So far I've found an [url= http://www.jessops.com/online.store/categories/products/olympus/sport-holder-for-tough-cameras-orange-csch-123-96609/show.html ]olympus case[/url] that might be an idea.
But generally something that makes it easy to get to, probably mounted to a shoulder strap whilst at the same time doesn't rattle around Any other bright ideas? Moon on a stick?
Posted : 28/05/2015 8:29 am
I have a Lowe Alpine case on hip let, I can reach, unhook, get camera out, take pic and put back one handed.
Posted : 28/05/2015 8:35 am
Alpkit stem cell.
Posted : 28/05/2015 9:11 am
I've tried various things and I just prefer to stick it in my pocket. Easy access, no kerfuffle.
Posted : 28/05/2015 9:15 am
[quote=matt_outandabout ]I have a Lowe Alpine case on hip let, I can reach, unhook, get camera out, take pic and put back one handed.+1
Posted : 28/05/2015 9:16 am
I guess something minimal like this[url= http://www.lowepro.co.uk/shop-by-carrying-style-pouches/dashpoint-10_ct284pd187.htm ] dashpoint lowepro one[/url] then?
Posted : 28/05/2015 9:25 am
Mine is from the AW range, so has a fold-away waterproof cover
http://www.fotosense.co.uk/lowepro-apex-30-aw-black.html
Posted : 28/05/2015 9:27 am
I've got the lowepro AW above. does the job. Can unzip with one hand and pull the camera out. Protection seems decent too. Lots of fitting options
Posted : 28/05/2015 9:43 am
If you don't want it on your hips, you could look at a "gas tank" type thing that sits on the top tube behind the stem? some might be padded/ robust enough.
Posted : 28/05/2015 10:20 am
We use a Samsonite Trekking case and pass the cross strap on the front of the back pack through the belt holder, secure and water resistant
Posted : 28/05/2015 10:37 am
I use a dashpoint 20 on the shoulder strap with a carabiner to stop it slipping.
Posted : 28/05/2015 12:09 pm
Mine is one of these - because a gert big hook opening is easier than a zip I find.
Posted : 28/05/2015 12:40 pm
I've got one of the Lowepro Alpine ones above. It straps onto my rucksack straps & I bought a cheap spring clip to make doubly sure it stays in place
Works well, well padded & comes with rain cover as mentioned above.
Posted : 28/05/2015 12:55 pm
I use a Peak Design Capture Clip. https://peakdesign.com/store/capturepov
It attaches to the rucksack strap, then the camera just clips in. It works nicely, holds the camera securely, and easy to unclip one-handed to take a photo.
I usually use it with a bigger Micro 4/3s camera, its maybe a bit excessive for a point and shoot. But I have used it with a waterproof compact, that works fine too.
Posted : 28/05/2015 12:56 pm
Thanks folks, plenty of food for thought there.
Posted : 28/05/2015 1:20 pm
That PeakDesign stuff looks brilliant!
Posted : 28/05/2015 4:16 pm
 cp
I use a nylon Camera pouch which straps around the shoulder strap of the camelbak, and a small caribiner round a loop to stop it dropping down. Genuinely don't notice it there when riding and gives very quick access.
Posted : 28/05/2015 4:32 pm
