Queston about Deore...
[Closed] Queston about Deore M532 chainset
 Earl
Are the cranks suitable for getting cut down/shortened?
I know they are not hollow inside but do they thin out at the back?
Posted : 04/07/2009 12:55 am
Why would you want to chop them down?
You'd end up with cranks over 25mm shorter....
Why?
Posted : 04/07/2009 7:56 am
 Earl
175 reduces to 155 for which is right for some.
Posted : 04/07/2009 8:53 am
and what are you going to hang the pedals off?
Posted : 04/07/2009 9:15 am
New threaded holes that you'd drill and tap after shortening the crank, I'd imagine...
Posted : 04/07/2009 9:47 am
aha - worked that out after I realised it wasnt a hollowtek crank ๐Ÿ˜ณ
Posted : 04/07/2009 9:53 am
 Earl
Yep - Highpath Engeering have a shortening service. 155mm is good for someone around 5.0 to 5.3 in height (27ish inseam).
Anyhow - anyone got a set to see if there is enough meat on the back next to the existing hole?
Posted : 04/07/2009 1:36 pm
this is taken from
zoomed and cropped.
You can see that the forging starts a recess just where the white circular sticker is.
Using the thread diameter as a scale you should be able to work out the length available.
Posted : 04/07/2009 1:48 pm
Earl - Ive just been in the LBS and he had a set of these in the cabinet so I asked him to dig them out.
The arm thickness starts to taper about 10mm from the edge of the pedal threads. There is still a quite substantial amount of metal but about 20mm away from the existing hole (155mm distance) its down to about 10mm from 15mm at the pedal thread area.
HTH.
Posted : 04/07/2009 4:19 pm
 Earl
Bummer. They will be too thin i.e Highpath refuses to cut them down if there is virtually any reduction at all even when I say they will be for light xc/city use. Probably the best thing.
Thanks very much Stoner.
Posted : 04/07/2009 9:02 pm
