question about my r...
[Closed] question about my revs
2 Users
i have a set of Rock Shox Revelation 426 U-Turn with Maxle lite now they lock out fine but should i be able to adjust the compression just slightly as it seems ican either have it only fully locked or fully open
Posted : 07/04/2009 8:22 pm
My 08 426 Dual-Air ones are like that.
Engaging the lockout, and using the floodgate adjuster as if it were the compression adjuster works to dial in the compression, but only when locked out. You can then run two compression settings by flicking between 'locked-out' and unlocked.
Not exactly ideal though
Posted : 07/04/2009 8:36 pm
