putting forks bk on...
[Closed] putting forks bk on a frame
just sent my fox forks off for a service had no problems taking them off but ive noticed both bearings have pretty much died so will be needing new ones, i know i should of looked but in what order do you put bearings back in the headtube on the forks :/
Posted : 14/08/2010 9:53 am
 nuke
You mean the headset bearings? What headset is it?
Posted : 14/08/2010 9:55 am
its on a cannondale prophet 1 so fsa
Posted : 14/08/2010 9:56 am
 nuke
Before the edit time runs out change the subject heading for this thread to "Cannondale Prophet headset help" or similar...should get you more help as its not that regular a headset
Try the FSA tech pages...
http://www.fullspeedahead.com/fly.aspx?layout=tech&taxid=155
:edit: out of time...oh well.
Posted : 14/08/2010 10:04 am
sorry i posted it and went out :/ thx for the info though
Posted : 14/08/2010 11:10 am
The bearings from an fsa orbit z fit - the bottom cup is not used though - cannondale use their own reducer cup. Usually cheaper to buy the orbit z headset than just the bearings. Bear in mind that they are marginally different in shape.
http://www.cyclestore.co.uk/productDetails.asp?productID=18412
Posted : 14/08/2010 1:03 pm
hmm its just 2 bearings that look very similar to this http://www.chainreactioncycles.com/Models.aspx?ModelID=37520
Posted : 14/08/2010 1:31 pm
i know what i am talking about - ignore me if you want! They need to be the correct angles
Posted : 14/08/2010 1:42 pm
didnt say u didnt know, its just first time putting forks on for me thats all so its slightly confusing..
Posted : 14/08/2010 1:57 pm
trust me you need the bearings from an FSA orbit z put them in the correct cups - its obvious when they are in your hands
Posted : 14/08/2010 2:01 pm
ok cheers ralph ill jot that down and see if the lbs has them in ๐Ÿ™‚
Posted : 14/08/2010 2:08 pm
