Putting a route tog...
[Closed] Putting a route together on Viewranger made of sections of other routes
Does anyone know if it's possible to combine sections from several routes to make one big route on Viewranger ?
For example, I've got several routes already on Viewranger, but if I want to use sections from those routes and combine them into one new route, is this possible?
Still not figured out how to do this and I'm not sure if it even has this functionality
Posted : 14/03/2016 2:32 am
 nach
I don't think viewranger does editing, just recording. You probably have to export the routes you have as GPX files, use something on a computer to edit them, then reimport.
Posted : 14/03/2016 9:41 am
Viewranger will edit routes OK the problem is if you want to combine several routes you need to open them all at the same time. I can't think of anything that does that. I'd probably either create the big route manually or export all my smaller routes as GPX files and bodge together in notepad.
Posted : 14/03/2016 9:56 am
