Push tuning vs dual...
[Closed] Push tuning vs dual flow upgrade
2 Users
 gra
It's coming round to time to get my Sektor solo air serviced, and am looking at getting it upgraded at the same time. I have the option of the dual flow rebound, like what is in Revelations or getting it Push tuned. Any thoughts on what would be the better option, or will both give similar results?
Cheers.
Posted : 06/01/2014 6:52 pm
 gra
Anyone with experience of either upgrade on a Sektor?
Cheers.
Posted : 07/01/2014 1:12 pm
I had some Pike forks PUSH'ed a few years ago as the damper could not handle high speed repetative hits and would pack down becoming harsh; the PUSH gubbins fixed it.
The Revelation Team forks I've had with the Black-Box damper never behaved in the seme way as they had the dual-flow damper.
If thats your problem either would fix it - but I can't tell you which is better, although IIRC Loco did once say the Dual-Flow damper is a better solution and has some adjustability wheras the PUSH is one set-up fix.
Posted : 07/01/2014 1:28 pm
