Push tuning rear sh...
[Closed] Push tuning rear shock
Just wondering whether anyone has done it and whether it is actually worth the extra money, can you tell the difference??
Posted : 17/07/2010 6:11 pm
Had my DHX coil pushed made quite a bit of difference,made it better on small stuff(roots) and handled the bigger stuff nicer,Felt less harsh through its travel.
Posted : 17/07/2010 6:20 pm
Had a Septune serviced and pushed a few years ago and yes it did make a fair bit of difference all across the travel. Just waiting for a call that the parts are in so I can send off my 2010 RP23 with the large volume can, as it blows throught he travel to quick for my liking when set at the correct sag and I don't like the ride when I run it harder
Posted : 17/07/2010 6:29 pm
I had my septune pushed as well. Made a massive difference to the ride of my stumpy, and TFT are very good to deal with too.
Posted : 17/07/2010 6:41 pm
Thanks chaps, makes my decision a lot easier. Push tuned it is.
Posted : 17/07/2010 7:28 pm
Finchie85 - whats the shock you have??
Posted : 17/07/2010 7:36 pm
Its a fox float rp2
Posted : 17/07/2010 7:52 pm
Ah, they offered me a replacement smaller air can for mine as thats half the problem afaik thats all.
Anyhow cracking service and turn around
Posted : 17/07/2010 7:55 pm
Anyone see the mag test standard fox, pushed fox and some other shocks ? Standard fox came out on top. Carlos sound like you need a standard vol air sleeve to me.
Posted : 17/07/2010 7:58 pm
Yeah read the test. We spoke about it when I called them and based on the chat settled for the Push tune. I agree though in what your saying as my old RP23 was fine with the smaller air can.
Posted : 17/07/2010 8:03 pm
I had my Fox Float on the back of my Enduro PUSHed a while back and am still very pleased with the results. The rear suspension tracks noticably better, just as well in fact as the Romic coil I occasionally use.
Recommended.
Posted : 17/07/2010 8:08 pm
Carlos pop the c-clip off on your hv air can remove the outter sleeve, fill it with grease refit. Reduced volume air sleeve.
Posted : 17/07/2010 8:11 pm
Carlos- as per mr frosty-Remove can and fill with something. I used plastic Drinks bottle,Cut sections out and fitted them,until you get the ride characteristics you want.
Like this
Posted : 17/07/2010 8:27 pm
Nah, not my idea of fixing the issues. Thanks though.
Posted : 18/07/2010 10:00 am
The biggest problem is that you'll end up having to have all your future shocks pushed.
Posted : 18/07/2010 4:40 pm
Used it for the first time last night, it is so smooth now!! Keep preparing myself for bumps that are now no longer there!! Highly recommended!!
Posted : 20/08/2010 1:06 pm
Carlos, as per nicolaisam's post..I'd try the shim out before sending to TF. Its an actual Fox procedure, you can buy shims from Fox.
Check this thread out http://forums.mtbr.com/showthread.php?t=503070
Posted : 20/08/2010 1:21 pm
 LoCo
Grease in the hv air can is the answer for reduced air volume and curing the problem. ๐Ÿ˜€
Posted : 20/08/2010 1:53 pm
