Pugsley Fork 135mm ...
[Closed] Pugsley Fork 135mm or 100mm?
[#2045839]
Following on from yesterdays Fat Front Karate Monkey discussion KM frame is on the way 🙂
My preference is to go for Pugsley fork that'll take standard 100mm front hub, so I can use my standard 29er wheel as well. And I've already got standard disc front hub available for 26" wheel build.
Is there any dis / advantage to the 100 over 135 Pugsley fork before I make final decision.
Posted : 01/10/2010 2:02 pm
put a 104mm tire in a 100mm fork ?
Posted : 01/10/2010 2:05 pm
You do know the a to c length on the Pug fork will leave you with a somewhat twitchy front end and lower the BB don't you?
Posted : 01/10/2010 2:10 pm
I do now!
So I could go for Salsa Enabler which has same AtoC as KM, but then I'd need 135mm hub....
Any other options?
Posted : 01/10/2010 2:32 pm
The enabler seems to be the only fat fork with the correct a to c unless you go custom...
Posted : 01/10/2010 3:07 pm
