PSA - Ragley frames...
PSA - Ragley frames for £170
Does anyone happen to know what size bolts are used to hold the rear hangers on a Ragley Big Al?
Same size bolt as cleat bolts - I lost a couple from my Blue Pig and found these fit perfectly.
Posted : 21/04/2024 8:24 pm
mashr and mashr reacted
Timely thread.
I had the exact same thing on my Mmmbop. The bolts on the alloy frames are M5, 8mm countersunk with 3mm hex head. They are, indeed, made of cheese. I've ordered some stainless steel ones to replace them. I would have preferred them to be 4mm hex head as the larger key size would probably resist rounding a little better.
I believe the steel frames take 10mm bolts rather than 8mm. That also seems daft given the relative hardness of the frame material.
The non-driveside assembly team at Ragley seem to have heard of loctite, but the driveside assembly team seems not to have. 🙂
Daft, really - they expect you to put headset cups in, but don't trust you with six little bolts.
Posted : 21/04/2024 9:22 pm
I could be wrong, but I think if you read this thread front to back, there's a link to aftermarket bolts.
Could have been somewhere else I saw it though. I bought some anyway.
Had heard about the loose bolts pre building mine so nipped them up (the originals). They definitely are soft - kinda wondering if this is to make them sacrificial to save the frame threads and hanger?
Posted : 21/04/2024 10:02 pm
I think sacrificial bolts are a bridge too far for Ragley, TBH.
I guess you could argue they are sacrificial to your Allen keys as the grade of material in the bolt head would struggle to round a candle...
We'll see how the replacements do - just lightly nipping up the originals with a nicely cut, sharp and hard Allen key bit from a proper torque wrench set has nearly buggered the heads of a couple. And that is literally just snugging them and hoping the loctite does the job.
Posted : 21/04/2024 10:38 pm
First ride / shake down, finally.
Nothing has fallen off so always a bonus.
The Ragley Big Al is one comfy yet super quick bike that is going to prove super versatile I think.
Those 36s turn in very well indeed.
XT/SLX 12 is quite superb.
200mm dropper really nice and slammed.
TRP 4-pot surprisingly good for the money.
Wicked Will 2.6F and Nobby Nic 2.4R a weird combo that is actually proving really good so far.
[url= https://i.ibb.co/Mnrp7PM/1000055358.jp g" target="_blank">https://i.ibb.co/Mnrp7PM/1000055358.jp g"/> [/img][/url]
[url= https://i.ibb.co/GMB4Swt/1000055359.jp g" target="_blank">https://i.ibb.co/GMB4Swt/1000055359.jp g"/> [/img][/url]
Posted : 25/04/2024 9:41 pm
A bit good, aren't they?
So comfy and capable - almost easy to forget you're riding a HT at times
Posted : 25/04/2024 9:49 pm
^^ exactly. Living on the South Downs it makes the need for FS relatively limited. So much so that I have sold the Izzo.
I am really glad I went for L at 6ft. XL would have pushed things a little too far. And reduced the dropper travel.
How are you getting on with yours?
Posted : 25/04/2024 10:01 pm
Loving it. Need to try and get out on it this weekend, not had a ride on it for a few weeks. At 5'11 with long legs, large seems to suit me perfectly too with a 200/210(?) dropper - not slammed though 😬. As you say the trp brakes are decent. The weak point on mine I think though is the Lyrik Selects. I have three tokens in and still seem to blow through the travel. Other than that, all good
Posted : 25/04/2024 10:12 pm
felltop and felltop reacted
That's disappointing about the Lyrik. Are they recent? Or could it because they are recent? Oil level ?
As you can see I don't know much about forks but I had old Lyrics and they were brilliant.
TBF I am really impressed with the cheapo 36 Rythm and the old Grip damper so perhaps that says more about my inability to push forks 😂
Posted : 26/04/2024 10:29 am
Most of the time you’re paying for more adjustment rather than outright performance with forks and shocks.
Posted : 26/04/2024 10:58 am
These were the recent CRC discounted Lyriks
Had an old set on my ebike and they were fine. Probably just need to do a bit more tweaking
Posted : 26/04/2024 11:16 am
FWIW I copped a set of the CRC Lyrik Ultimates when they bottomed out at £340.
I sent them to J-Tech to have the travel reduced and their custom tune/settings as it was very little more to do at the same time.
I've not had Lyrik's before, but I've got Pikes on my other hardtail and had other RS forks. Usually I find the recommend settings on the Trailhead app, plus very little compression damping suits me. When the Lyriks came back with suggested 85psi (compared to 91 on TH), HSC on about half way and the LSC on about 2/3 of the way, it seemed really odd.
Honestly not sure how much J-Tech's optimisation of the internals affects this, but they're working beautifully, strange settings and all. Best I've ever ridden.
Posted : 26/04/2024 12:25 pm
Got some stainless steel 12mm total length, countersunk, M5 bolts with 3mm hex heads - 20 for £5.69 off Amazon.
Absolutely fine - snugged down nicely with a dab of blue loctite. No iffy feeling of potential rounding in the head at all.
Posted : 26/04/2024 5:44 pm
@fwnderextender do you have a link? Or want to sell a set?
Posted : 26/04/2024 6:52 pm
Typed a longish follow-up as top link didn't work. Got a 502 error and lost it all. Not typing that lot out again.
"12mm countersunk M5 screws" in Amazon is your friend - RC Screw Shop.
Posted : 26/04/2024 9:41 pm
@nickfrog
Took the big boy out yesterday. Gets better and better every time I ride it 😊
Lyriks seemed ok weirdly
20240427_084911~2
Posted : 28/04/2024 1:02 pm
Nice image! Wide angle. I like it
Thing is, despite weight and geo, it climbs really well too.
Although it's my first 29 HT so perhaps I just perceive the wheel size effect primarily.
Posted : 28/04/2024 1:33 pm
@TheArtistFormerlyKnownAsSTR what's going on with the sky? Where's the rain?
Posted : 28/04/2024 2:15 pm
Sun came out properly for a while after the pic. Alas, this was yesterday. Today, the rain - it returns and it's making up for its non appearance yesterday
Posted : 28/04/2024 2:25 pm
“That is the perfect bike for round here” - one of the Marshalls at the Hamsterley Forest enduro this weekend. 🙂
Posted : 13/05/2024 11:34 pm
^^ that sounds about right.
Meanwhile after dropping the Camelback last year I have now dropped the hip bag and I am totally unicumbered. It's very nice to ride bagless.
[url= https://i.ibb.co/dLBSNsW/IMG-20240514-112029.jp g" target="_blank">https://i.ibb.co/dLBSNsW/IMG-20240514-112029.jp g"/> [/img][/url]
Posted : 14/05/2024 12:19 pm
dc1988 and dc1988 reacted
@nickfrog what is that bag? Or isbit custom?
Ian
Posted : 14/05/2024 7:53 pm
@breninbeener
It's home made but I can make one for you for £169.99 delivered.
Or you buy a cheap Evoc replica from Merlin.
https://www.merlincycles.com/evoc-multi-frame-pack-281129.html
Posted : 14/05/2024 8:21 pm
breninbeener, Del, Del and 1 people reacted
Fitted a 2.6 at the back of the Big Al which is officially rated up to 2.5, although the Rekon is not an aggressive tyre.
[url= https://i.ibb.co/yS04PRN/Screenshot-2024-06-09-22-09-21-248-com-miui-gallery-edit.jp g" target="_blank">https://i.ibb.co/yS04PRN/Screenshot-2024-06-09-22-09-21-248-com-miui-gallery-edit.jp g"/> [/img][/url]
But still plenty of clearance so I reckon, pardon the pun, even a less shallow tread 2.6 would be fine.
Posted : 09/06/2024 11:14 pm
As above ^ clearance in the frames is much more generous than they state. I've got a 2.6 WTB Trailstar (and they have big side knobs) on a 40mm rim in the back of my Blue Pig. I reckon a 2.8 would fit fine too.
Posted : 10/06/2024 12:07 am
Yes I was thinking that about a 2.8. Probably not needed depending on rider's weight but nice to have that option on a hardtail!
Posted : 10/06/2024 12:31 am
Page 14 / 14
