PSA: Pike 454 air u...
[Closed] PSA: Pike 454 air u-turn £320 @ CRC
[#497699]
I've recently been building up a new bike (blur 4x)and needed some ~140mm forks for it. Found
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=33073 ]these 454 air Pikes at CRC for £320[/url]. Bargantastic I thought. As i've now received mine I'd thought I'd share.
Think they may be new old stock as they have '07' stamped on the back of the crown brace.
But they're still lovely and bouncy
Posted : 24/04/2009 12:21 am
what colour are they, vain i know but it MATTERS
Posted : 24/04/2009 12:45 am
now CRC are getting members to advertise for them!!
Posted : 24/04/2009 1:38 am
they're black. Not sure how crc got me to post this - maybe all their ads on this site are exerting control over my feeble mind
Posted : 24/04/2009 8:18 am
badgergoo - Is the steerer steel or alu?
Posted : 24/04/2009 9:10 am
454 = ally steerer.
and yip they are bargaintastic.
Posted : 24/04/2009 9:13 am
vortexracing - the reason i'm asking badgergoo about the steerer is because there was a batch of oem 454's made with steel steerers.
Still good value at £320 with a steel steerer, if they are proper after-market forks with an alu steerer they are fantastic value though.
Posted : 24/04/2009 9:20 am
mine just arrived, aluminium steerer.
Posted : 24/04/2009 2:31 pm
Mine have been the biggest PITA fork I've ever owned. If I was buying again I would forego the small weight saving and get coils.
Been back twice for repair under warranty. A pain to balance the +/- chambers, foreever loosing oil out the valves.
This may just be my experience.
Love another set of cheaper Pikes I have on another bike.
It is cheap though.
Posted : 24/04/2009 2:41 pm
Apparently mine have just been dispatched.... 😀
Posted : 24/04/2009 2:43 pm
Must resist the urge to purchase 🙁
Posted : 24/04/2009 2:55 pm
fwiw, always do the neg air pressure with the fork upside down, stops oil getting in the pump and giving a duff reading. i just had mine pushed and they feel really good. smashed the neg air valve off down snowdon rangers path last week though so waiting for new parts in the post.
Posted : 24/04/2009 3:13 pm
Always have done them upside down. Still get oil out of both ends.
A PUSH upgrade is probably on the cards as with new fork prices going a little crazy I don;t think I'm going to make a swap to Coil 454s (unless someone readin is in the market to sell me some?).
Hey ho. They aren't shit by any means but I'm finding them a right bugger.
Posted : 24/04/2009 4:46 pm
just ordered some myself, have some 09 rev's but wanted something beefier with a bolt through. I take it the 07's are also the same as 08's etc (matte black with white pike decals and same internals etc)? Funny that there listed as 09's!
I'm assuming that they don't come with a shock pump or anything?
Hugh
Posted : 27/04/2009 10:15 pm
I'm a bit torn between the Pike Airs on CRC or the 09 Rev U-Turns on Merlin...both more or less the same price but save some weight on the Revs or gain some stiffness with the Pikes 😕
Posted : 27/04/2009 10:19 pm
qr revs are cooked spaghetti compared to pikes.
Posted : 27/04/2009 10:21 pm
cheeky monkey.what was up with them to be sent back.mine spitt out a bit of oil out of the -ve valve.
Posted : 27/04/2009 10:23 pm
That is a good deal!
Posted : 27/04/2009 10:50 pm
That sounds like them matte black and white decals.
They didn't even come in a rock shox box - it was a CRC one. No pump, but they did have the manual, a hose guide and a random lump of plastic.
Posted : 27/04/2009 10:53 pm
Ok cool, thanks for that. OEM then! No problem as the OEM rockshox forks tend to be the same as the after market except for the box and shock pump which isn't really a big deal when there as cheap as they are!
Can't wait to try them now!
hugh
Posted : 27/04/2009 11:02 pm
Mine turned up today, CRC box, bag of bits, lump of plastic that I assume is for mounting them on racks? no pump.
I hope they are '09 given that CRC are listing them as this years model!
Posted : 28/04/2009 12:03 am
Just ordered as couldn't resist. I was thinking of getting Revs with Maxle but the RRP on those is around £640: the Pikes are half the price yet still Air, U-Turn 110 to 140mm, and Maxle plus, going from the SRAM site, not even that much heavier 😀
Posted : 29/04/2009 9:22 pm
got mine today! Very happy 😀 Have had to order a longer brake hose thought as the pikes seem to be taller than the 09 revs 😕
Can't wait to have a ride on them tomorrow.
Posted : 29/04/2009 9:26 pm
[i]Have had to order a longer brake hose thought as the pikes seem to be taller than the 09 revs [/i]
Oooo, hadn't thought of that...still, first things first, got to get a 20mm front wheel!
Hugh - So do they look the same as per the 09 forks on the SRAM site...[url= http://www.sram.com/en/rockshox/allmountain/pike/#tab1 ]http://www.sram.com/en/rockshox/allmountain/pike/#tab1[/url]
Posted : 29/04/2009 9:32 pm
Some great deals on Reba/ Revelations assuming the steerer length is ok
http://www.merlincycles.co.uk/?fn=product&productId=1842&categoryId=18
Posted : 29/04/2009 9:39 pm
Hugh - So do they look the same as per the 09 forks on the SRAM site... http://www.sram.com/en/rockshox/allmountain/pike/#tab1
Yep they look exactly the same to me!
Posted : 29/04/2009 9:41 pm
[i]Yep they look exactly the same to me! [/i]
Posted : 29/04/2009 9:46 pm
Recently pulled the trigger on the Fox Vanillas on CRC (£349) - deffo OEM but no regrets so far!
Posted : 29/04/2009 9:50 pm
I wouldn't hesitate for a second to buy another set of my 454 Coil Pikes.
They are simply brilliant.
Posted : 29/04/2009 9:57 pm
 Gnnr
Were these supplied with a full length steerer?
Cheers, G
Posted : 01/05/2009 10:48 pm
They're OEM forks (2007s?). Mostly fine but you won't get a warranty. Well, nothing beyond the statutory 28 days you get with more or less any Internet purchase, anyway.
: P
Posted : 01/05/2009 10:54 pm
[i]They're OEM forks (2007s?). Mostly fine but you won't get a warranty[/i]
...and you know this how?
Posted : 01/05/2009 11:12 pm
Yes they come with a full length steerer.
Think their 08 models (or 07) as I have another pair bought last year that are identical, although sold as "08 Pikes" and they also have 07 stamped on the underside of the crown.
Posted : 02/05/2009 12:07 am
I'd suggest the RS just havn't changed the design for a couple of years- they are the latest model, first released in 2007. Call it 2007 or 2009 - whatever its still great. The crown casting has a 07 stamp but RS could have well produced a batch of them in 07 and are still working their way through them.
Not sure why you would believe they would not have a waranty, what with the fact they came with waranty info.
Posted : 02/05/2009 5:49 am
