Under £200 if you use CLEAR2022 as well 😉
Good PSA. 👍
Clutching at straws here, but would this fit a wheel with a 135 QR hub?
Should fit the hub just fine, but a 135 bike wont have a boost chainline - so the chainring might sit a bit too far from the centre to be ideal - not a major issue, it might be OK, but if there are problems, you could just replace the chainring with a non boost one to correct it.
The cassette fits a standard freehub. Whether you'd be able to fit the crank and BB to a QR frame, and get an acceptable chainline is another matter.
I have had an NX drivetrain on my bike for a couple of years. I expected to have to change it for something better but it hasn't let me down yet. I did swap the chain for a GX after a bit - just for peace of mind.
Non-Boost crank in that one, although is that a simple chainring swap to one with Boost offset? I'm not familiar with SRAM stuff in general.
(I see the Boost groupset is available for £259.99 on CRC)
@doomanic - @aLLy above is right, it's a non boost chainline, so forget what I said above, should suit your bike just find.
That’s me £200 lighter then. Cheers OP!
Glad it helped someone.👍
And me - thanks OP, perfect timing!
Hmmmm. Very tempted to get this to drag my 2010 Stumpjumper FSR kicking & screaming into relative modernity. It's still on 3x9.
Not sure about the bottom bracket compatibility though.
It's the carbon version with a press-fit BB - the description required is this:
SM-BB91-42A - it's often described as custom BB91, but I have no idea whether a standard press-fit BB would work (89.5/92mm - BB92 PF41).
Although - SRAM DUB pressfit BBs get terrible reviews - so perhaps it would be a pain in the arse going forward....
Keep existing crank and convert it to NW 1x?
Sell the new crank.👍
I only look into bb compatibility when I have to, it does my bloody head in.lol
Not a bad idea, poop!!
Oh well, ordered one. Going to look a little odd in a 26er steel hardtail but should work well
Good psa
...any recommendations for a replacement non-boost chainring that would fit the chainset as Id like a bit larger than 32T but all the sram ones on CRC seems to be £70+?
The SRAM steel chainring is only about £17 IIRC.
