£10
Very very good.
I use mine all the time on the bikes.
Hex have ball end BTW.
brilliant heads up, thanks. I've lost enough of my current ones to make this worth going for...
ta.
BTW - double ended ratchet spanners up soon:
http://www.lidl.co.uk/cps/rde/xchg/lidl_uk/hs.xsl/index_34802.htm
doesn't seem that great a deal to me. Yes they're half the price of the Halfords Pro ones but with Halfords you get a) more spanners, b) a flexi-ratchet end, c) a lifetime warranty AND they will no doubt be on offer soon.
I wonder if these drill bit sharpeners are any good? http://www.lidl.co.uk/cps/rde/xchg/lidl_uk/hs.xsl/index_34803.htm
And that compressor..much cop?
Maybe I won't bother then 🙂
which one? The proper 24L one - yup. Good value and normally 3yr warranty on lidl stuff.
the airbrush one - you can probably do high flow with a track pump for a quick burst (or ghetto inflator with track pump)
im thinking of the airbrush one, for airbrushing
ahh in that case should be fine. I have a really old one for airbushing that is noisy and not very smooth but that should be a lot better and much easier to live with than a full size one for airbrushing. But saying that, if you do all your airbushing in one place then I would still be tempted to buy a proper compressor as you can use it for other things.
+ one advantage of a proper compressor is you can have a proper regulator and set the pressure you want.
*strokes beard* methinks more research is needed. Plus this helmet spraying milarcy may be a fad..
