PSA -29er pikes £36...
[Closed] PSA -29er pikes £365 140mm £439 130mm
Thanks, must stop looking at PSA, 140s and a xt front brake ordered, its not what you spend its what you save
Posted : 22/10/2016 9:44 pm
Any ideas on the offset on these? Can't find reference to the part number..
Posted : 22/10/2016 9:49 pm
If only there had been a 120mm in there!
Posted : 22/10/2016 9:51 pm
Pretty sure you can drop 130 to 120 by cutting down the air shaft (you might need to recut the thread too).
Posted : 22/10/2016 10:00 pm
That all sounds beyond me 😳
Posted : 22/10/2016 10:04 pm
Get drunk first!
Alternatively, it's just an air shaft swap. Not totally sure which one you need for a 120mm 29er Pike but they're about £27 if you can find the right size. And it's a really easy swap- barely any harder than a lowers service. (Which I know a lot of people are freaked out by but a lowers service is as hard as undoing 2 bolts, wiping your arse, putting toothpaste on a brush, and pouring a shot)
Posted : 22/10/2016 10:11 pm
Have emailed them re. The offset - could be just want I want on my fuel 29
Posted : 23/10/2016 9:12 am
They will be sold out before you get a reply.
Just assume 51mm, I reckon.
You can replace air shaft and sell the one it comes with to adjust height.
Not a very difficult job, but one bit can be quite tricky.
Posted : 23/10/2016 10:57 am
Can you increase the travel to 150mm with a new air spring?
Posted : 23/10/2016 11:33 am
Think so. My mate bought some 120's and extended them to 140.
Posted : 23/10/2016 1:01 pm
46mm apparently.
Posted : 24/10/2016 10:18 am
Cool.
I could have lived with 51mm but 46mm is preferable.
Posted : 24/10/2016 10:37 am
I'm the other way around.. have 46mm, new frame is 51mm! Probably debatable how much noticeable difference it'll make, but would've been nice to swap at minimal cost.
Posted : 24/10/2016 10:47 am
Looks like mine has been shipped. Think I read something a while ago where Mojo did a test on different offsets on a 29r and 650b Enduro
Posted : 24/10/2016 11:27 am
Just been told by Canyon the 29ers are 51mm offset
Posted : 24/10/2016 11:39 am
Ha, I was told 46mm! Only one way to find out..
Posted : 24/10/2016 11:53 am
frogstomp - Member
True story... When I fitted my 34s in place of my Pikes, it felt exactly like how people describe the difference between offsets. I was just about getting convinced that this stuff matters, til I discovered that actually both forks had the same offset.
I haven't even bothered to find out what offset my 36s are, they feel normal so I'll just presume they're 51.
Posted : 24/10/2016 2:37 pm
I think [url=www.bikeradar.com/mtb/gear/article/pushing-the-limits-of-fork-offset-an-experiment-45343/]this[/url] is the article Tracey is referring to.
[quote=Northwind]When I fitted my 34s in place of my Pikes, it felt exactly like how people describe the difference between offsets. I was just about getting convinced that this stuff matters, til I discovered that actually both forks had the same offset.
Same offset but different A2C so different in other ways? But yeah, the differences are probably fairly negligible to the masses.
Either way, nice new forks for the new frame won't be bad, and gives me an excuse to use the old forks on a Shan GT!
Posted : 24/10/2016 2:42 pm
hmmmm some people I know could end up wasting some good whisky, have a minty fresh bum and a shitty smile
Posted : 24/10/2016 2:50 pm
frogstomp - Member
The a2c was about the same with these 2 forks, less than 2mm different I think. Obviously the damping and way it used travel was different so things get lost in the mix
Posted : 24/10/2016 3:19 pm
Once mine arrive will post up the offset, would love to be able to do a lower service but think it may be beyond me.
Thought the 28T SRAM chain ring was a good buy but apparently it may not come with the spider.
Posted : 24/10/2016 3:24 pm
They have arrived and there 51mm offset (under crown) they have no service kit/pump but do come with bottomless tokens ,but unlike the advert there is no sag marker on the leg and black graphics 😐
Posted : 26/10/2016 8:44 pm
Looks like some how I've accidentally ordered two 140 Pikes. 😳
Hopefully I can cancel one set, before they're processed.
Bit of a shock when I checked my balance!
Posted : 26/10/2016 8:53 pm
Mine arrived as well, not too fussed about the 'OEM style' sale.
now I need a 130mm airshaft, anybody got one?? 😉
Posted : 26/10/2016 8:59 pm
Mine are at the Sheffield depot. Should have been ddelivered today. Will ring them tomorrow and rearange the delivery. Dont seem to be able to do it online. Hope mine have the black graphics and dont need another shock pump.
Posted : 26/10/2016 9:01 pm
Any one know what steerer length?
Posted : 26/10/2016 9:35 pm
uncut
Posted : 26/10/2016 9:46 pm
[quote=Vortexracing]now I need a 130mm airshaft, anybody got one??
VR you have email..
Posted : 26/10/2016 10:37 pm
51mm and murdered out here.
Packaging was like a lucky dip.
Posted : 27/10/2016 10:01 am
My 130mm have just arrived - 51mm offset and 2x tokens - great for the money!
Posted : 27/10/2016 1:06 pm
Mine have arrived this morning, packaged well. Stealth graphics and 51 mm offset. A couple of chips, one on the crown and one on the front of the bridge. Can live with them as will probable get more on my next off. The front brake although shown as a right hand in the picture is a left hand so not much use apart from spares.
Posted : 28/10/2016 9:45 am
Ive had mine. Looks like a head race has been fitted but nothing else. Great PSA, thanks OP!
Posted : 28/10/2016 10:06 am
Mine are on the way.
Just need to either source a 120 air shaft or cut down the one that comes with it.
Posted : 28/10/2016 10:43 pm
Breadcrumb - you have mail!
Posted : 28/10/2016 11:15 pm
Thanks frogstomp 8)
Posted : 29/10/2016 4:09 pm
Just back on from my first ride with these, wow, pretty impressed and they still need a bit of fine tuning.
Posted : 05/11/2016 3:10 pm
Just received mine, 140mm version and they look lovely. Come with tokens and totally blacked out stanchions.
Posted : 08/11/2016 8:41 pm
Mine are fitted and fantastic,
thanks Peasant
Posted : 08/11/2016 9:14 pm
Yep thanks. Best PSA for me ever on here.
Posted : 08/11/2016 9:22 pm
has anyone opened them to see if there are tokens installed already?
Posted : 13/11/2016 10:30 pm
Two tokens in the 140 with two extra supplied.
First ride round Whinlatter with them today, I am really impressed with them, very composed. Wish I'd got some ages ago!
Posted : 13/11/2016 10:37 pm
Not opened them to see whats in. Tokens have gone in box with all the other tokens. This set has gone on Abigales Camber Evo. Had to set them at minimum pressure to get full travel. Cant go wrong with the price.
Posted : 13/11/2016 10:43 pm
All sold out in 140mm now.....
Posted : 13/11/2016 10:50 pm
Good to see people are benefiting from psa,s posted on here 😀
Posted : 13/11/2016 11:04 pm
Took mine to Bounce to have a 130mm air shaft in, Frank there said they had very little oil in them, so just be careful, may be worth dropping the lowers and checking.
Posted : 13/11/2016 11:12 pm
