Code : SUMMERDAYS
Its " SUMMERDAZE"
you sure doggcam? 😉
You sure dezb?
Excellent, now I just need a time machine to unbuy the headset I bought two days ago... 🙂
Looks like Superstar are about as sure as all the above!
If you use all 3 codes it gives you 75% off!
I'd convinced myself I could make do with the wheelset I've got for my 26er up until a few seconds ago...
They often have multiple codes for the same result. Makes it easy to tell if you're getting the info from email facebook etc.
Been waiting for the inevitable bank holiday offer to buy some chainrings 🙂
That’ll be the third set of wheels I buy in 2 weeks then. 25% off puts them in line with second hand offerings so might as well get some new ones.
Thanks!
anyone had experience with their bb's? i need a replacement for my threaded gxp and might give em a whirl,
Treated myself to some 30/35mm rims on Electro hubs for £150, must be some sort of bargain.
Anybosy want to buy the Bonty Dusters I bought last week and haven’t taken out of the box?
Out of stock on the pads I want ..
Anyone know if Uberbike have a bank holiday code ?
Argh, no boost wheelsets.
just bought a wheelset for my gravel bike after my Kinesis set failed (rims cracked around eyelets)
Gambled a bit - not a fan of cust service that you can't call and speak to a human - over whether they will fit.
<div>The main use is on a gravel frameset with 15mm front and 12x142 rear, but I also want to be able to use them if necessary as a spare set for my road bike with standard QR front and rear (135mm rear spacing)</div>
<div></div>
<div>However I couldn't order them with the 15 / 12x142 fittings because they didn't have the convertors to QR at each end listed as spares, only the front. Hence I ordered the front as a 15mm, with a QR convertor spare; and then the rear as a QR because I <u>could</u> order the convertor to 12x142....... hope that makes sense! But the convertor kits are for Switch / Switch Evo / Switch Ultra, and the hubs are Switch Ultralite. I'm hoping they will be compatible (the hubs on the wheelset are convertible and common sense would suggest you use the same parts) but if not they'll be going back.</div>
<div></div>
<div>(kind of posting this here in case SSC are looking on and can answer. Or anyone else)</div>
