Protection/Care for...
[Closed] Protection/Care for a steel frame?
Recently got myself a steel 29er mountain bike and I have heard tales of people putting GT85 in the frame after a ride and turning the frame upside down overnight while others simply clean the bike. Is there anything I should be doing (apart from cleaning it well) to protect the frame from rust been as though its steel?
Posted : 29/05/2013 2:49 pm
Kona's
Lava dome - from new 1996
Cindercone from new 1996
Kona Kilaeau used but bought in 1998
Never used anything on them and all are in pretty much constant use.
My input
NO
Posted : 29/05/2013 3:27 pm
I put Waxoyl in the frame before I built my El Mariachi but then I'm using it packrafting and fully expect it to get submerged at some point 😉
Posted : 29/05/2013 3:29 pm
don't need to do anything special. Just treat it the same as any other bike.
but if you really want, then treat it with waxoyl before building the bike up.
Posted : 29/05/2013 3:36 pm
My El Mariachi is currently fourfilling a role as a commuter, it was submerged last night in a top-tube deep ford. All my bikes get a similar level of love and attention and none have done anything worse than a dribble of rusty water in the BB.
I'd never worry about it.
Posted : 29/05/2013 3:41 pm
Grease in assemblies, bolts, BB shell etc. Grease your seatpost fairly regularly, esp. after a wet ride.
Posted : 29/05/2013 3:56 pm
Thanks guys
Posted : 29/05/2013 5:54 pm
wot buzz said, and wot I said on a thread earlier today:
I recently had my steel frame renovated by A Well Known Frame Builder, who's been building for 35+ years.
I asked about rust protection for the inside, they recommended waxoyl or framesaver.
I asked whether it's a good idea, or a nice-to-have if you're a bit paranoid, and whether he bothered with his own frames.
The reply:
No doubt you will be familiar with the saying "Do as I say, not as I do!"
Posted : 29/05/2013 6:16 pm
I've seen frames rust out from the inside - it takes several decades at least. If you plan to keep your bike that long, it's worth using Framesaver.
If not, then don't bother 😉
Posted : 29/05/2013 6:20 pm
I put a waxoyl type product in my steel frame before it got built. It cost less than £10 and took about half an hour to do (but it does need a bit of drying time - overnight). I was a bit annoyed/concerned the other day when I took the seat post out and it had rust stains on it. But thinking about it now, there probably isn't any waxy stuff left in the seat tube because the seatpost is regularly removed.
Posted : 29/05/2013 8:04 pm
Use a chemical rust converter such as Vactan or Kurust if there is any rust it will be converted into metal if the metal is fine a protective coat will still remain.
Takes about 15mins to dry.
Waxoyle I'd imagine would be rather thick and also easily scraped off at contact points.....
Posted : 29/05/2013 8:21 pm
How is this scientifically possible?
Posted : 29/05/2013 8:57 pm
 tsd
I treated my 456 with boiled linseed oil before building it up as an alternative to framesaver or waxoyl.
Posted : 29/05/2013 9:07 pm
jackthedog - Member
Don't ask me I don't make it.....
But to be a little more accurate call it a metallo-organic compound or some shit...
Whatever it works and even if not converting rust still acts as an excellent protective coat. 🙂
Posted : 29/05/2013 9:20 pm
Acf-50. Designed for aircraft and works a treat on my motorbikes exposed parts. A little goes a long way. 🙂
Posted : 29/05/2013 9:24 pm
[quote=thisisnotaspoon ]My El Mariachi is currently fourfilling a role as a commuter, it was submerged last night in a top-tube deep ford. All my bikes get a similar level of love and attention and none have done anything worse than a dribble of rusty water in the BB.
I'm thinking more about sea water 😯
Posted : 29/05/2013 9:34 pm
Beware of Waxoyl if you ever plan on a respray, stoving causes it to melt, run out through the drain holes, and ruin the finish wherever it mingles with the paint/powdercoat.
Posted : 30/05/2013 8:09 am
