Problems with Helit...
[Closed] Problems with Helitape on On-One carbon frames (Northwind was it you?)
So I'm 95% through building up my Lurcher and was going to start taping it up soon but I had some recollection of someone having problems with helitape screwing the finish of the On-One carbon frames. ๐Ÿ˜
Thought it might have been Northwind that had problems?
Or am I misremembering something else and getting my wires crossed?
โ“
Posted : 27/09/2013 1:01 pm
I think the issue is that if you remove the helitape the laquer comes off with it leaving a poor finish.
If you put it on and leave it there it's ok.
Posted : 27/09/2013 1:02 pm
Unless there's a chemical reaction issue, you should be able to safely remove it using a hair dryer to heat the glue first.
Posted : 27/09/2013 1:25 pm
I've had Helitape on my C456 for over a year now and it's not damaged the frame finish at all. I have no experience with damage on removal though as i've not touched it since fitting.
Posted : 27/09/2013 1:27 pm
 MS
I have a couple of bits where the laquer has come off on removal of helitape. I didn't heat up prior to removal so that may work.
headtube has generally been ok when removing, the bits on mine that is worst is the chainstays.
Posted : 27/09/2013 1:31 pm
Yup, it was me... The response I got was that the carbon frames are incompatible with helicopter tape, the finish lacks resistance to the adhesive and that it'll damage it. (hairdryer makes no difference incidentally)
I think in practice, it's only an issue when you remove it- the adhesive seems to weaken the finish, then it comes off. It's not structural- skin deep only- so like wwaswas says if you leave the tape on, it'll probably be fine.
(have to say, I don't necessarily believe anything they say, they're a bit short on credibility with me after their blatant fibs regarding this... But like the murphys...)
Posted : 27/09/2013 1:44 pm
OK thanks all.
Posted : 27/09/2013 3:14 pm
Wow really? That's pretty amazing.
Posted : 27/09/2013 3:18 pm
Well, for clarity, it makes the tape come off much easier, so it does make a difference- it just still takes the finish off too. So no difference in the result, is what I should have said.
Posted : 27/09/2013 3:35 pm
