Problem with Debona...
[Closed] Problem with Debonair shaft upgrade.
4 Users
Hi. Just replaced my older Yari air spring with a Debonair replacement. All seemed fine until I went to push in my rebound adjuster - the one with no grub screw, just like a push in allen key. But, it does not go in, the hole that is the bottom of the older shaft is not there. Have I bought the wrong thing? I rode it gently, and seems like it is working but didn't ride hard, just in case.
Any thoughts/knowledge?
Posted : 28/07/2020 10:26 pm
Have you mixed up the two bolts?
The one in the bottom of the air spring side is solid. The one in the damper side has a bore through it for the rebound adjuster.
After all, you've only made changes on the air spring side, the damper side is unchanged.
Posted : 28/07/2020 10:29 pm
I know what I did. I changed the damper shaft. I laughed, was annoyed and relieved all at once. Doh!
Posted : 28/07/2020 11:16 pm
LOL done the same in the past.
Posted : 29/07/2020 9:25 am
You mean the rebound rod, piston and shims were sat on the workbench after you'd finished?
Posted : 29/07/2020 2:39 pm
Surely it’s just that you put the wrong bolt in each leg, so the adjuster now fits on the airspring side?
Been there done that the first time I did an airspring change!
Posted : 29/07/2020 2:47 pm
