Problem with crank ...
[Closed] Problem with crank bolt and fixie riding
 juan
Well that is the second crank I shatter using a fixed rear wheel.
First one was a ISIS race face, and not only did the BB gave up, the crank holes for the bolts were all ovalised.
The second one is a XT, and when I was riding last sunday I ended up with only one bolt maintaining the ring to the crank.
What am I doing wrong?
Posted : 06/01/2011 2:17 pm
Sounds like the chainline isn't straight (wheel not straight in dropouts / dropouts bent?), or the chain tension is too tight. This could put uneven pressure on the chainring.
Posted : 06/01/2011 2:20 pm
 juan
Cheers, I'll try with the crank that comes with the bike, a smaller ring ,shorter arm and 5 bolt and see what happens
Posted : 06/01/2011 2:22 pm
too strong - stop pushing the pedals sooo hard ๐Ÿ˜‰
Posted : 06/01/2011 3:02 pm
I shed chainring bolts more frequently when riding fixed, but I normally notice before I'm down to just one! I cracked a Middleburn spider by riding with only 4 out of 5 bolts fitted. My advice is to use threadlock and check regularly!
I agree with Pixelmix too - don't get too anal about keeping the chain super-tight, so long as your chainline's good.
Posted : 06/01/2011 3:11 pm
You are using single ring specific chain ring bolts aren't you?
ISIS bottom brackets are well known for only lasting a couple of rides.
Posted : 06/01/2011 3:13 pm
Possible chain is too tight. That will arse the bb
But do use the cromo bolts we sell at charliethebikemonger.com Fixed is no place for alloy cheese.
Isis sucks. I go square taper on White industries cranks.
Posted : 08/01/2011 12:54 am
[i]What am I doing wrong? [/i]
Nothing. Welcome to my world.
Posted : 08/01/2011 1:10 am
