probably a stupid b...
[Closed] probably a stupid bottom bracket question........
Can I use a hollowtech 2 chainset with a race face x-type bottom bracket?
(I suspect not as its a bit of a tight fit)
Posted : 08/10/2014 5:20 pm
I was using Raceface Evolve XC cranks with a Raceface X-Type, then swapped the BB to a Hope one and it fits fine. So you should be okay... probably.
Posted : 08/10/2014 5:29 pm
Works fine, till the Race Face seizes (mine lasted about a year)
Posted : 08/10/2014 5:30 pm
Do I need to use the 'gentle persuader' then as when trying to install the axle is tight in the bearings?
Posted : 08/10/2014 5:34 pm
I think some other standards have different axle diameters for each side - not sure which they are but I'd suggest you at least satisfy yourself that there's no play at either side (I guess also one side could be too narrow but I guess that'd be obvious)
Posted : 08/10/2014 5:49 pm
It's equally as tight regardless of which side I try to insert it, I guess I should stop being tight and fork out for a new bb anyway - just have wasting stuff
Posted : 08/10/2014 7:39 pm
Bigger hammer (it'll be fine)
Posted : 08/10/2014 7:42 pm
It shouldn't need as sledge should it? I was hoping the lump would sort it, ah **** it what's the worst that can happen 8)
Posted : 08/10/2014 7:54 pm
I have just gone the other way fitting a rf xtype crank into a shimano bb. The fit is fine.
Posted : 08/10/2014 8:31 pm
