Pro2 front hub bear...
[Closed] Pro2 front hub bearing removal
3 Users
Has anyone done this? I assume it's possible to drift out both bearings along with the spacer tube in one hit? Have ****ted it pretty hard already but they don't seem to be shifting. Any tips (apart from taking it to the LBS 🙂 )? Tools are limited to a few large hammers, lots of sockets and lengths of rod suitable for drifts. No bearing pullers etc...
Posted : 27/04/2009 12:16 pm
IIRC you have to drift them out from the inside as there is a step in the hub to seat the bearings against - using a drift knock the spacer tube to one side then drift the bearings out from the inside
heat the hub ( rag wrapped round plus hot water) to make life easier. Freeze the new bearings
Posted : 27/04/2009 12:18 pm
The bearings come out of each side. To do this inset a screwdriver and lever the centre tube to one side, and then tap the bearing from the inside, you'll probably have to move the tube round a bit and tap the bearing from all sides, evenly.
Once one bearing is out, out comes the tube and tap the other bearing out from the inside.
Easy peasy.
Posted : 27/04/2009 12:19 pm
Cheers, glad I didn't perist with the drift right through method 😉
Done now
Posted : 27/04/2009 1:14 pm
Another DIY disaster averted due to Super STW!
Posted : 27/04/2009 1:17 pm
