I have a HOPE Pro II and 20mm axle (Marzocchi) front set up.
There's a very slight 'wiggle' coming from the hub / wheel. It isn't noticeable when I'm riding. It feels a little like a lose headset or a loose disk rotor. It's definitely coming from the hub though. As though the diameter of the axle is a fraction too small for the bearings.
It's not the pinch bolts.
Just live with it or is something wrong?
Thanks
Sounds like bearings time. Should be a quick, easy job.
+1 needs new bearings
Silly question but is it done up tight enough?
Done up tightly.
New bearings it is then.
Thanks all
I had the same issue through 2 sets of bearings (some from a local bearing supplier, and some from ebay, but both "high quality") when I went from QR to 15mm.
As soon as I put in proper bearings from hope, the issue went away.
Use proper bearings, and the proper tools, is my advice.
