I have so far tried three road saddles, a Spec Romin (too wide), a Charge Knife (ok-ish) and a San Marco Concor.
The concor is by far the comfiest in shape and allows my legs to move freely (large quads from squatting) - but the support for the sit bones is just a bit narrow.
Any suggestions as to a similar shape but a little wider?
Have you had your sitbones measured?
Adamo?
If you liked the Romin otherwise- what size was the one you had? Go a size down?
Which width of Romin?
what do you use on your other bike?
I have a ragley cheeky (a mountain bike saddle!! shock horror) on my road bike, it's a velo 1200 and is that perfect inbetween size and comfy for me
google the width sizes, if you find out the width of the knife then that should give you a good pointer to what works
Worth finding a shop that does test saddles. I think on specialized ones you can buy one and then return it for something else if it doesn't suit.
The charge spoons are quite rated so you may want to try that.
I have had a spoon and a knife and a henge on my mtb. I think the knife was closest.
I have a pretty flexible upper body. Admittedly the henge was a 155.
Maybe an arione Versus?
why not use the same one you have on your mtb?
Brooks cambium. It's like you are being carried along by angels
velosam - Member
Worth finding a shop that does test saddles. I think on specialized ones you can buy one and then return it for something else if it doesn't suit.The charge spoons are quite rated so you may want to try that.
mrs antigee did the specialized thing and worked well - was ok with her old saddle but very happy with new one
otherwise does seem like a lottery with expensive pain if get it wrong - recently swopped my CX/drop bar hybrid/adventure bike saddle as had literally worn out - went for a charge spoon - carefully measured my old (specialized) saddle and got it right but had a good starting place
