Can I convert this hub to standard 132 Q/R ? Or is it like the 150?
In that the shell is too wide
If yes, then is it as simple as changing just the end caps, or is a new axle required???
You just need the correct axle end caps and bingo.
I might even have some somewhere. I'll have a look tomorrow. If I can find em and you love you. If you pay the postage you can have em.
The Pro 2 has a 15mm O/D axle.
The Pro 2 Evo has a 17mmm.
I know the Evo can be changed just with end caps, not sure about the older Pro 2.
I'm selling Evo qr ends if that's the hub u have....
so changing the end caps reduces the 'non EVO' Pro 2 from 142mm to 135 mm?
Thanks for the offer Toppers, may be interested...
Basically I need to know this...
My frame is non maxal, 135mmm.
Just bought pro2 wheelset with 12 x 142 rear hub set up.
Do I need an axle AND caps, or just caps?
[url= http://www.hopetech.com/wp-content/uploads/2014/03/PROIIREARassy.pdf ]Looks like an axle & end caps are required.[/url]
Axle and end caps for Pro 2.
Just end caps for Pro 2 Evo
I'm pretty sure if you put the QR end caps on the 12mm axle, it'll work. But it's probably not a very good idea since the 12mm axle is so snappy.
yep I think you are correct snaps....
Damn was hoping for the easy/ cheap option lol
Soz. I think what I have is for an evo.
Thanks all ....
Am now thinking, if Im changing the axle, I may as well get 10mm bolt on
I might have some end caps, then you would just need the axle
I can look tomorrow
Pro 2 Evo - End caps only.
Pro 2 - Axle and endcaps, or Evo axle, end caps and freehub body.
Just gone 135QR to 142x12 so I have a Pro 2 axle and en caps going - £12.50 posted 🙂
Cheap Superstar 10mm bolt-through, nice and non-creaky and won't undo like a bolt-on.
