Preload adjuster wo...
Preload adjuster won't turn?
1 Users
Just converted my Ohlins RXF36 M.2 from air to coil. Initial bounce feels ace and sag is pretty much spot on with no preload but if I try to add preload the adjuster feels stuck.
The parts are brand new and I noticed the adjuster was pretty stiff before fitting, wonder if I should have dripped some lube into it. Pretty confident I assembled everything correctly. Any ideas folks?
Posted : 19/07/2022 8:54 pm
I'll update this just in case anyone else is searching with the same problem. It seems it is possible to turn the adjuster slightly beyond the final detent. I had done this and that seems to be what jammed it when the top cap was tightened down.
Posted : 20/07/2022 4:50 pm
