Powercordz gear cab...
[Closed] Powercordz gear cables
[#839480]
Anyone tried them?
Have a bit of spare cash burning a hole and I'm tempted to get a set for "research" purposes (lol).
Posted : 04/09/2009 4:28 pm
Yes I've got a pair.
Wouldn't bother again to be honest, the plastic coating pulls off very easily when clamped, that exposes the fibres and makes them pretty weak, don't do them up as tightly and they're prone to slipping through the clamp bolt!
Posted : 04/09/2009 5:43 pm
Ah ok then. Seemed like a good idea in theory. I'll keep my money and let it burn my pocket some more.
Cheers!
Posted : 05/09/2009 4:39 am
They are great in thier first use. Lighter and stronger plus they won't stretch.
But, like njee20 says they do split when clamped as instructed, so if you need to re-position the cable, clean the inner/outer or swap them onto another bike then they are a real pain and pretty much useless.
So if you get a year from an inner cable, then they might be worth it? I'd use them again if I felt I'd keep them in place long enough.
Posted : 05/09/2009 6:54 am
Could you put some heat shrink tubing over the clamp area to give a better bite and stop the crushing?
Posted : 05/09/2009 7:35 am
wonder if theyd be any good in a rohloff twist grip?
Posted : 05/09/2009 8:25 am
I was wondering about that I must admit, or even just some turns of electrical tape, the problem is that once the fibres are exposed they just go everywhere, if you could keep them together they'd be fine.
I use mine in Alligator I-links, which seems a good combo, but when they wear I'll just stick normal cables in.
Posted : 05/09/2009 9:56 am
I've been running a set with ALligator I-links for about 2 years i think. Dunno about them splitting... I've removed mine and re-clamped them a bunch of times and i've yet to split the outer or anything.
Seem good to me, they haven't needed any attention since i fitted them to be honest.
Posted : 05/09/2009 10:00 am
You've got the older ones haven't you? The 1.4mm ones or whatever they were?
Mine are the newer, thinner 1.2mm ones, maybe they made the coating thinner, I can pull it off with my fingers!
Posted : 05/09/2009 10:07 am
Ah yes i do, forgot about that. Mine are 1.5mm (i think) which might explain why they are tougher. I certainly can't pull the coating off. I did read on MTBR about the 1.2mm ones stripping in use.
Posted : 05/09/2009 10:09 am
I wonder why they went to 1.2 then? Can't imagine it was for weight saving!
Maybe worth firing off an email to the makers and see if they'll send a replacement set out if they do squish and fray?
Posted : 05/09/2009 10:58 am
So they fitted through the liners on Nokon and I-links, yes that's not a bad idea.
Posted : 05/09/2009 11:00 am
The 1.5mm fits the I-link Linner fine no mod needed etc.
I would be mighty suprised if they would replace them from user stipping them...
Posted : 05/09/2009 11:22 am
Wouldn't hurt to email them though explaining the problem. I would! Might have been a bad batch, and early run of the 1.2mm version. Sending an email costs nowt 🙂 You said it had been raised in MBR so it's clearly an issue, and not necessarily a user error that caused it.
Posted : 05/09/2009 12:40 pm
Any reccomendations where to get them at a decent price?
For research purposes of course.. 😀
Posted : 05/09/2009 1:09 pm
Ordered mine from the US.
Not sure if there is a UK distributor any more.
Posted : 05/09/2009 8:50 pm
