powder coat and ca...
[Closed] powder coat and carbon question
question can a carbon/aluminium frame be powder coated (I know the paint wont take to the carbon)or are they assembled already painted? temperature reaches 200 degrees I understand its more about the resin than the carbon fibre in relation to the heat so im curious if any members have had this done
Posted : 07/01/2013 8:00 pm
Powder coating relies on electrostatic for the powder to stick to the frame. Can't see it working on a non metallic material...?
Posted : 07/01/2013 8:13 pm
correct,its more about will the carbon be affected by the heat to bake it on
Posted : 07/01/2013 8:27 pm
Carbon conducts though so shouldn't it stick to that too?
As to the heat all depends on the resin used in manufacture. I'd check with the manufacturer if I were you.
Posted : 07/01/2013 8:36 pm
The resin will most likely be 180C or 120C cure temp, either way 200C will seriously damage it.
Posted : 07/01/2013 8:46 pm
powder coaters stated 200c so not looking good
Posted : 07/01/2013 9:01 pm
UPDATE manufacturer has stated the rear is not powder coated but front is so need to get a paint match for the powder coat if I get it done.
Posted : 08/01/2013 11:35 pm
I thought about this last year and the companies I asked wouldn't go near it. Conductivity and high temperature were the issues.
Posted : 09/01/2013 9:05 am
Carbon frames are usually wet painted. Is this not an option?
Posted : 09/01/2013 9:30 am
