Post to IS caliper...
[Closed] Post to IS caliper mounting problem - XTR M985 caliper to M965 shifter?
 yan
Anyone tried fitted a new XTR M985 Post mount caliper to an old XTR M965 flip shift changer - will lever modulation be the same? Just bought some new DTSwiss forks which are Post mount and the old M965 caliper is IS mount with a 160mm disc. Tried various adapters incl from KCNC from Clee Cycles and nothing seems to fit - without a larger disc and big mods to the adapter...
Posted : 30/08/2011 3:35 pm
IIRC new brakes push different amounts of fluid. Not sure if the older levers will work with the newest sort of calipers and vice versa as a result.
Posted : 30/08/2011 3:42 pm
 yan
Thats what I was thinking, wat dod you mean by IIRC?
Posted : 30/08/2011 5:14 pm
 yan
ok i see..........
Posted : 30/08/2011 5:18 pm
Would it not be easier & cheaper to go up a disc size rather than trying to change the calipers on your breaks.
Failing that just buy a replacement post mount m975 caliper as i'm sure they're switchable with M965. Rather than pricking about with cross compatability issues with different model ranges.
Posted : 30/08/2011 5:30 pm
 yan
Juat looking for the easy option really. I was thinking that an m985 caliper would be easier as theyre easily available - although more expensive. I think Post mount M975 are pretty rare. The disc option seems a fair bit of work and not sure if it will work in the end and need to go upto 180mm or even 200mm disc. Its only a lightweight xc big and 160mm is plenty powerful!
Posted : 30/08/2011 6:00 pm
M975 only came in IS i think. The best spec PM caliper would be an XT M775 one.
Posted : 30/08/2011 9:09 pm
